Theviper1987 Posted January 20, 2016 Share Posted January 20, 2016 Right the problem I'm having is. Every now and again I get a miss/hiccup. The fuel pump relay clicks off and on instantly, the rev counter bounces and the lights on the ecu flashes off then back on. Some times it will keep running, some times it cuts out. Iv put a multimeter to the relay and when it clicks I'm getting 12v up the ignition wires(brown) I loose the earth from the ecu,(not sure if i loose the earth or it spikes to a posative. it happens that fast I can't see that volts on the multimeter (blue/purple) Which in turn I loose the 12v going to the coils and fuel pump. I have disconnected the blue/purple wire from relay and put my own earth in to a earth on the dash, it then in turn stops the relay from clicking but the rev counter and lights on the ecu still do the same(it doesn't cut out but u do hear a change in engine tone). I thought it could be a dodgy vr sensor loosing signal or something but it's still the same after changing it. All wiring to plugs and joins are solder so I doubt it's a dodgy crimp terminal somewhere. Here is a list of bits I have changed; Vr sensor Edis8 module ECU plug with the wires prewired in the plug Ht leads Spark plugs I have also tried someone else's ecu with my map loaded on to it and still the same. Any help will be listened to. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 20, 2016 Share Posted January 20, 2016 How's your wiring done? Do you have the capacitors run off the coil packs? Sounds like resets. Quote Link to comment Share on other sites More sharing options...
Theviper1987 Posted January 20, 2016 Author Share Posted January 20, 2016 Do you mean this? The black wire with the suppression. No I haven't Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 20, 2016 Share Posted January 20, 2016 Correct, not always required, but can help. Be interested to see your wiring scheme....? Quote Link to comment Share on other sites More sharing options...
Theviper1987 Posted January 20, 2016 Author Share Posted January 20, 2016 This is the wiring diagram I used Quote Link to comment Share on other sites More sharing options...
Theviper1987 Posted January 21, 2016 Author Share Posted January 21, 2016 I'm not running a stepper motor tho Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 21, 2016 Share Posted January 21, 2016 And how are your earths? Quote Link to comment Share on other sites More sharing options...
Cheesy Posted January 22, 2016 Share Posted January 22, 2016 Maybe a couple of pics of the engine bay so we can see some of the actual wire paths Quote Link to comment Share on other sites More sharing options...
Theviper1987 Posted January 22, 2016 Author Share Posted January 22, 2016 All sorted.. some how I had got a set of bp6es's fitted swapped them for bp6es's and she is all fixed Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 22, 2016 Share Posted January 22, 2016 umm, you mean BP6ES rather than BPR6ES? Quote Link to comment Share on other sites More sharing options...
Theviper1987 Posted January 23, 2016 Author Share Posted January 23, 2016 Sorry yes auto correct on my phone obviously didn't know what I wanted to say Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 23, 2016 Share Posted January 23, 2016 Cool, yes they can help Quote Link to comment Share on other sites More sharing options...
WilliamTods Posted July 23, 2016 Share Posted July 23, 2016 another test for the clutch is rev at about 4k then try to pull away in 3rd it should stall but it really doesnt sound like clutch more like plugs and leads possibly a sensor.. sounds like a cold problem... let the car sit for about 10 mins before driving next time you need to do a fair distance 30mins or more driving and see if it occurs then? Quote Link to comment Share on other sites More sharing options...
