Coil spring downgrade
guyadawson
The dampers will put a torsional load on the front axle when moving, but that should be controlled by the radius arm bushes, so while moving the dampers inside the springs would reduce that torsion and the forces on the bushes, I can't see that it's a "must", after all, the dampers and suspension work just as hard with the air springs as with coils.
There is no change at the rear.
