squi5566 Posted February 12, 2016 Share Posted February 12, 2016 hi, in detail if possible, can some one tell me or show me how to install a 300tdi fuse box into a 200 tdi rrc(1993 to be exact), ive cut out all the old crappy fuse links, and now have two bunches of wires, 1 from the range rover side and 1 from the 300tdi fuse box, which wires connect to which wire or fuse, all the 200tdi wires are orange and another colour, all the fuse box wires are brown and another colour, some fuses i need and some i dont, i have no diagrams to follow, and not much else, and id prefer not to set my car on fire, if possible, so can someone assist me please, many thanks in advance. Quote Link to comment Share on other sites More sharing options...
Nigelw Posted February 14, 2016 Share Posted February 14, 2016 Not done it myself but can see it being easy enough to do. Get your multi meter out and set for continuity to test and find out which wires are which, or a battery and a test lamp will do, work out which wires you need to power which circuit. I wouldn't have bothered personally, it's far simpler to use better links and wire them accordingly. Something like this http://m.ebay.co.uk/itm/Strip-Link-Midi-Fuse-Holder-for-Striplink-Midi-fuses-Fuseholder-fits-all-/121209019230?nav=SEARCH Mount on a piece of plate and once fitted and connected fill with vaseline to ensure they stay corrosion free. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 16, 2016 Share Posted February 16, 2016 Forgive me if I sound harsh but would it not have made more sense to have identified everything BEFORE cutting out the wiring ? Try googling the relevant wiring diagrams for starters. You could also use the 300 Tdi fuse box pictorial to identify which fuse does what. Mo Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted February 16, 2016 Share Posted February 16, 2016 Fair point Quote Link to comment Share on other sites More sharing options...
task Posted February 17, 2016 Share Posted February 17, 2016 A couple of the fusible links in my RRC blew before my ownership as a result of the heater motor shorting, I replaced them with some in line fuses rather than a complete fuse box. The blue wires are for towing electrics, the red ones are the replacement links. Quote Link to comment Share on other sites More sharing options...
Nigelw Posted February 17, 2016 Share Posted February 17, 2016 A couple of the fusible links in my RRC blew before my ownership as a result of the heater motor shorting, I replaced them with some in line fuses rather than a complete fuse box. The blue wires are for towing electrics, the red ones are the replacement links. Oooo like that installation, tidy too Pretty much as I was trying to explain, Don't have fuzzy linx on pre 93MY D1s lol Quote Link to comment Share on other sites More sharing options...
task Posted February 17, 2016 Share Posted February 17, 2016 Oooo like that installation, tidy too Pretty much as I was trying to explain, Don't have fuzzy linx on pre 93MY D1s lol Thanks Inner wing looks a little scruffy in the photo but it's been cleaned since then! The fuses are pretty hefty, normal blade fuses don't really cut it. Quote Link to comment Share on other sites More sharing options...
Nigelw Posted February 17, 2016 Share Posted February 17, 2016 Exactly what do those links feed? I ask as I don't have them and wonder why they added them for 93my> 200Tdi and 300 got full upgraded box. Quote Link to comment Share on other sites More sharing options...
task Posted February 17, 2016 Share Posted February 17, 2016 They feed aircon blowers, radio, heater blower and something else. Quite a power draw when it's all turned on, although it's unlikely you'd run the heater and aircon blowers at the same time! Quote Link to comment Share on other sites More sharing options...
Nigelw Posted February 18, 2016 Share Posted February 18, 2016 My aircon is manual, wind to the right to switch it on, wind to the left for off, it was a deluxe model with dual climate control as my passenger has one on their door too 2 Quote Link to comment Share on other sites More sharing options...
