Window Tinting Removal
Landrovernuts
Hot-air-gun and wallpaper scraper. Take care not to focus the heat on one spot for too long or you may have the glass shatter. Once you've got the worst of it off, wipe over with Methyl Chloride [Wear gloves! Ensure good ventilation!] to remove the adhesive streaks....
I read about the heat - it said the heat made the glue stick to the tint rather than the window. It did the opposite.
Everywhere I heated it the tint came away leaving the vast majority of the glue on the window - everywhere I didn't heat was better.
I used loads of window cleaner and half a dozen single sided razor blades.
Like these:
https://www.ebay.co.uk/ulk/itm/361057318228
Like these:
I'm in the midst of this job myself, using the same blades in one of those holders you can get for them. It only takes a light touch to get most of the tint off, and the layer of adhesive beneath it. I used acetone after to finish up.
Thankfully Defenders have flat glass, which makes this job far easier than it could be.
I tried every solvent in the garage to remove or soften the film and its adhesive, but warm air worked the best.
In many cases the film peeled of leaving the adhesive on the glass, and a flat scraper with brand new blade was the only way to remove that.
