Cornish Rattler Posted December 5, 2016 Author Share Posted December 5, 2016 Next week hopefully I will be able to start working on the tdi engine againĀ as I have been battling this cold I have had this past 3 weeks then once Christmas is over and done with I will order a log burner and everything I need to fit it into my garage to keep me nice and warm in the future Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted December 12, 2016 Author Share Posted December 12, 2016 Off this week so I decided to start removing the cyl head, timing case, sump and ladder frame, checked the bearings and pistons for play and I couldn't find any at all, really pleased so tomorrow I can start cleaning the engine down where we couldn't get with the jet wash then start building it back up again obviously with new seals and gaskets and a Disco timing case ready for fitting into the chassis Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted December 13, 2016 Author Share Posted December 13, 2016 (edited) Sorry its took so long but here are some pic's of the tdi engine so far, note the damaged Def timing case has now been changed for a Disco one but everything else is staying as is Edited December 13, 2016 by Cornish Rattler Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted December 17, 2016 Author Share Posted December 17, 2016 Cleaned everything down the other day and today started fitting everything back on, adaptor plate, flywheel and clutch assy on, timing belt on and tensioned, just got to put the head on yetĀ Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted December 19, 2016 Author Share Posted December 19, 2016 A couple of pic's of the battery tray cut down to allow the tdi engine to fit in, although its not toughing its still close so I will cut it down some more or decide if its worth saving it and cut it off all together and fit the battery under the seat Quote Link to comment Share on other sites More sharing options...
Arjan Posted December 19, 2016 Share Posted December 19, 2016 You might as well remove the battery tray completely. Makes for more room. Nice Project !! Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted December 19, 2016 Author Share Posted December 19, 2016 Yeah its looking like I probably will anywayĀ as there won't be much to secure the battery properly so more then lightly it will be coming off but I will let my son see it first Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 20, 2016 Share Posted December 20, 2016 Are you fitting the Tdi air filter in the position previously used by the oil bath filter? Ā If not, you can move the battery forwards by extending the mount towards the rad panel. Ā Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted December 22, 2016 Author Share Posted December 22, 2016 On ā12ā/ā20ā/ā2016 at 6:50 AM, Snagger said: Are you fitting the Tdi air filter in the position previously used by the oil bath filter? Ā If not, you can move the battery forwards by extending the mount towards the rad panel. Ā No we plan on fitting a KN cone filter Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted February 18, 2017 Author Share Posted February 18, 2017 As you may have read in my other thread I am taking this project on as my own and selling the 90 so watch this space Quote Link to comment Share on other sites More sharing options...
Bandog Posted February 19, 2017 Share Posted February 19, 2017 Nice work fellas. I put my battery under the seat in the end. Good luck with the progress.Ā Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted February 19, 2017 Author Share Posted February 19, 2017 5 minutes ago, Bandog said: Nice work fellas. I put my battery under the seat in the end. Good luck with the progress.Ā Yeah now its mine I will just lob the battery tray off and put the battery under the passenger seat Quote Link to comment Share on other sites More sharing options...
Bandog Posted February 19, 2017 Share Posted February 19, 2017 Good man.Ā Make sure you use 450amp cable, and put plenty of heat shrink on the live where it abrades on things it touches.Ā I have a 200 amp circuit breaker in there, just in case anything like that happens, to prevent fire. It's got a huge bosch battery from a jag.Ā Quote Link to comment Share on other sites More sharing options...
Bandog Posted February 19, 2017 Share Posted February 19, 2017 No room for a battery here, because of discovery steering box Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted February 19, 2017 Author Share Posted February 19, 2017 11 hours ago, Bandog said: No room for a battery here, because of discovery steering box Yeah think I will go for an Optima yellow top like I had on my last oneĀ Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted February 20, 2017 Author Share Posted February 20, 2017 12 hours ago, Cornish Rattler said: Yeah think I will go for an Optima yellow top like I had on my last oneĀ Nice neat job that, sadlyĀ i can't weld and although the tdi power steering system converted to fit a series truck is the way to go I will just have to suffer and stick to manual steering Quote Link to comment Share on other sites More sharing options...
Bandog Posted February 20, 2017 Share Posted February 20, 2017 If you can wee, you can mig weld!Ā Learn on scrap until you are confident mate.Ā Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 28, 2017 Author Share Posted March 28, 2017 Hopfully work will start on the 90 next weekend we will start by painting the replacement bulkhead and smooth roof ( both already bought before deciding to sell ) and need to be fitted anyway then once they are both painted we will start removing the old roof and bulkhead, swap everything over from the old bulkhead to the new bulkhead then fit the replacement bulkhead and roof and get the 90 ready for selling, then once its sold I can then start work on the 2a but I will start by doing a bit of re-work as originally the 2a was for selling and everything that was replaced with BP parts will be replaced with decent parts now as the 2a will be a keeper and I have given myself 12 months to complete all being well Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted April 2, 2017 Author Share Posted April 2, 2017 (edited) On ā3ā/ā28ā/ā2017 at 10:45 AM, Cornish Rattler said: Hopfully work will start on the 90 next weekend we will start by painting the replacement bulkhead and smooth roof ( both already bought before deciding to sell ) and need to be fitted anyway then once they are both painted we will start removing the old roof and bulkhead, swap everything over from the old bulkhead to the new bulkhead then fit the replacement bulkhead and roof and get the 90 ready for selling, then once its sold I can then start work on the 2a but I will start by doing a bit of re-work as originally the 2a was for selling and everything that was replaced with BP parts will be replaced with decent parts now as the 2a will be a keeper and I have given myself 12 months to complete all being well Well that didn't happen yesterday but will happen tomorrow instead as whilst I was out getting the paint yesterday for the 90's new bulkhead and roof son rang me to say he has got chance of a load of flag stones we desperately need for in front of the garage for freeĀ so got back home and loaded the trailer on and with sons small van we collected 50 flag stones in 2 loads and then rough layed them to make life earier for driving in and out of the garage aswell as maneuvering the trailer to where I need it, then once the 2a is finished we will re-lay them properly but what I originally said for yesterday will happen tomorrow now instead Edited April 2, 2017 by Cornish Rattler Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted April 4, 2017 Author Share Posted April 4, 2017 I will open a new thread in the Defender section for the work being done on the Defender to keep it away from the Series section so anyone who is interested it what we are doing on the Defender please look on the Defender section Quote Link to comment Share on other sites More sharing options...
Arjan Posted April 4, 2017 Share Posted April 4, 2017 Looks good now that yard - well done. Those flag stones are heavy... Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted April 5, 2017 Author Share Posted April 5, 2017 22 hours ago, Arjan said: Looks good now that yard - well done. Those flag stones are heavy... Yeah I need to get some more yet to carry on further down to have somewhere to put stuff or park a vehicle on like possibly another Landy in the future Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted April 10, 2017 Author Share Posted April 10, 2017 I've been quite enjoying myself swapping the bulkhead over and swapping everything over onto it so I have decided on buying a new galv bulkhead for the 2a now so saving up like made now to buy one. Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted May 1, 2017 Author Share Posted May 1, 2017 Can't wait to get stuck into the 2a again so once the 90 is finished, refit some of the shelving I took down earlier this year to fit the log burning stove as I now have a load of 2a stuff and Defender stuff on the floor which I need to move onto the shelving to make room for the 2a coming back in as still have the head to refit and rotate the timing belt twice to reset the belt then start doing everything else to it as I have loads of work for it next year with the trailer aswell as a few fishing trips planned Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted June 4, 2017 Author Share Posted June 4, 2017 All the work we have been doing on the 90 should all be done by the end of the week then I can get the 2a back in and start work on it again, can't wait now Quote Link to comment Share on other sites More sharing options...
