200tdi fuel pump rubber cap/tube?
Good to extend it, but it needn't go far as the amount of air displaced by the diaphragm movement is relatively small.a six inch length of silicone windscreen washer hose bonded over the tube of that cap should suffice.
What he says too...^^^^ - never thought about that... I just copied the Camel set up...
I think the same is true of most breathers - the amount of air transfer is small, so six inches or so of vertical (downwards) extent from the highest spot oft he breather would probably be enough for axles, transmissions and anything else. The only breather that would need to cope with a large volume of air would be a fuel tank breather of a vehicle which had the tank cap immersed for protracted periods because of the fuel level dropping; the rest just suffer thermal expansion and contraction, which shouldn't be vast. People get carried away with breather kits, especially the makers, thinking they all need to extend to the snorkel.
