Leadbreakfast Posted May 13, 2016 Share Posted May 13, 2016 Hi there, Wanting some help here. My Range Rover 2002 td6 has decided to put up a inactive message so I plugged it it when I got home. Error said presure static when filling. Reset the code and it lets all the air out the rear so now on bump stops. Plugged it back in and the same message again. I can here the pump running but no go. Can anyone help? Quote Link to comment Share on other sites More sharing options...
qwakers Posted May 13, 2016 Share Posted May 13, 2016 seal in the pump is my personal bet. Quote Link to comment Share on other sites More sharing options...
missingsid Posted May 14, 2016 Share Posted May 14, 2016 Isn't this the same problem that Ed had in that rubbish program Wheeler Dicks? Piston or leaky pipe if not? Disco 3 suffers from cracked cylinder head but may not be the same type here? Have you tried googling it for your vehicle if it is a common problem not only will you find lots of different forum hits but also kits to fix them? Quote Link to comment Share on other sites More sharing options...
Leadbreakfast Posted May 14, 2016 Author Share Posted May 14, 2016 Pulled the compressor out to have a look. With it running should I be able to stop the pressure with my finger on the outlet pipe? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 14, 2016 Share Posted May 14, 2016 Hmm I would say not! Quote Link to comment Share on other sites More sharing options...
elbekko Posted May 15, 2016 Share Posted May 15, 2016 Nope, that's a good sign the compressor is toast. Open it up and have a look! Quote Link to comment Share on other sites More sharing options...
missingsid Posted May 15, 2016 Share Posted May 15, 2016 Piston ring repair kits are avalabie if needed but look around for price as there are some online who figure a half price of a replacement whole pump is OK! Quote Link to comment Share on other sites More sharing options...
