chewie2 Posted July 19, 2016 Share Posted July 19, 2016 i changed the front brake pads on my 1997 200tdi and when i tried to start it after i just got a loud clicking noise from the starter solenoid. i've had this before with other 4x4's but it just turned out to be a loose connection, I've checked all the terminals at the starter motor and they seem fine. I've never had starting problems before, always fired up first turn of the key. any suggestions? Quote Link to comment Share on other sites More sharing options...
chewie2 Posted July 19, 2016 Author Share Posted July 19, 2016 also i should note its not just one click like you get when the solenoid is worn and jams, I'm getting constant clicking from the solenoid when i turn the key Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 20, 2016 Share Posted July 20, 2016 Could be a flat battery or poor connection. Les. Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted July 20, 2016 Share Posted July 20, 2016 Constant clicking = flat battery. I presume a door was open or radio on whilst doing the brakes Quote Link to comment Share on other sites More sharing options...
Boydie Posted July 20, 2016 Share Posted July 20, 2016 Agreed either flat battery or poor earth, for a start the battery is on the wrong bloody side - furthest point from the alternator and starter motor if you ever have the time switch it to the passenger side, not a hard thing to do and secondly in my experience the single earth strap to the chassis is insufficient as it can corrode and give a poor connection, run a separate earth cable from the chassis earth point back to the battery earth lug, your problems should be over. Quote Link to comment Share on other sites More sharing options...
