xychix Posted October 21, 2016 Share Posted October 21, 2016 I'll have to repaint parts of the 110 SIII chassis after some welding, Will also try and paint the axle in the same go. I don't intend to take the chassis and axle completely apart, I'm actually just replacing the front-rearspring outriggers (welding new on) and will give the chassis a good paint. What paint do you advice? - I read rustoleum isn't advices as it doesn't mix with other paints (normally I'd mix rustoleum with some black metal paint) - I read RX5 requires the steel to be paint free (isn't gonna happen) Quote Link to comment Share on other sites More sharing options...
Flailbasher Posted October 21, 2016 Share Posted October 21, 2016 http://www.rust.co.uk/rust-proofing-paint-em121-epoxy-mastic/p404984 ive used this on all the parts underneath my Land Rover and it really does work. It's the best paint I've ever used for anything like this. Highly recommend it! Thiugh it is a bit pricy. Worth the money if you can afford it! Quote Link to comment Share on other sites More sharing options...
mickeyw Posted October 21, 2016 Share Posted October 21, 2016 I'm currently using Buzzweld's Chassis In One. Very pleased with the results. Very quick drying too. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 22, 2016 Share Posted October 22, 2016 I painted my last 109 with Hammerite with Waxoyl. I was very pleased with it. Les. Quote Link to comment Share on other sites More sharing options...
xychix Posted October 23, 2016 Author Share Posted October 23, 2016 I'm considering using owatrol on all the corners / thigh spaces and find some sort of black metal paint that can be mixed with owatrol. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted October 28, 2016 Share Posted October 28, 2016 Buzzweld CIO Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 28, 2016 Share Posted October 28, 2016 Red oxide or zinc rich primer over coated in Hammerite Underbody Shield or Schutz. 1 Quote Link to comment Share on other sites More sharing options...
daslandroverman Posted October 29, 2016 Share Posted October 29, 2016 On Friday, October 21, 2016 at 2:07 PM, mickeyw said: I'm currently using Buzzweld's Chassis In One. Very pleased with the results. Very quick drying too. I've been using it also. Comes up lovely. He does some more expensive stuff that works even better over rust, but best to have a chat with Craig and see what suits your wallet and application best. Easily found, both on Facebook and www.buzzweld.co.uk Quote Link to comment Share on other sites More sharing options...
Kevm Posted October 30, 2016 Share Posted October 30, 2016 I was wondering why you would want to mix anything with paint and was about to ask the question why? Then I googled Owatrol and now I am much wiser and understand - but why have I not heard of this stuff before? does it really work on LR rear crossmembers? Quote Link to comment Share on other sites More sharing options...
