Disco 2 Td5 Auto Box
brianc14
Hi, I have the well documented problem with the oil temp over heat red light coming on when towing up inclines.
I am going to put a temperature indicator strip (50mm x 18mm) to check the real Temp.
Can someone advise the best place to put this. I’m thinking maybe on the Oil flow pipe where it comes out of the Gearbox ?
Which one is flow? And how many degrees do I need to add to the indicated temp compensate between the oil inside the pipe and the temp sensed on the outside of the pipe. I have some doubt as to whether the warning light is telling the truth.
