Stretch 123 Posted November 14, 2016 Share Posted November 14, 2016 hi by heater fan has stopped working and when I done a diagnostic on it it came up codes 21 and 22 witch are left and right sac sunlight senors does anyone know where they are and how easy it is to replace them please its on a td5 discovery 2 51 plate Quote Link to comment Share on other sites More sharing options...
bear Posted November 14, 2016 Share Posted November 14, 2016 Have a look at the top of your dash in the centre. Black round plastic globe type thing. HTH, Griff Quote Link to comment Share on other sites More sharing options...
sierrafery Posted November 14, 2016 Share Posted November 14, 2016 (edited) Hi, if you've ran the diagnostic protocol while there was no sun against the sensor neglect that fault code cos it's false and leave the sunlight sensor alone, even if the code is real the sunlight sensor failure default has nothing to do with the blower( it's just "no solar heating correction" as in the table), if the blower doesnt work at all not even on full speed better check fuse F7 interior fusebox and if it's good some electrical skills are needed to rule out the relays cos there are two involved and a power transistor... Edited November 14, 2016 by sierrafery Quote Link to comment Share on other sites More sharing options...
Stretch 123 Posted November 14, 2016 Author Share Posted November 14, 2016 When I push the control panel I can here the motor working where would the relays be will check the fuse first and keep fingers cross . Quote Link to comment Share on other sites More sharing options...
sierrafery Posted November 15, 2016 Share Posted November 15, 2016 What motor can you hear working though cos you said the fan stopped? ...attached : C0153 = blower relay, C0901 = power relay, both involved Quote Link to comment Share on other sites More sharing options...
Stretch 123 Posted November 15, 2016 Author Share Posted November 15, 2016 When the control unit is turned on or off I can hear it coming from under the facia on the left side .it sounds like a motor but it could be something else Quote Link to comment Share on other sites More sharing options...
Stretch 123 Posted November 15, 2016 Author Share Posted November 15, 2016 Just checked the fuse and they are fine so either relays or senors or wiring harness Quote Link to comment Share on other sites More sharing options...
sierrafery Posted November 16, 2016 Share Posted November 16, 2016 I say again, as long as the blower doesnt work on max speed setting which gives it direct feed it has nothing to do with any sensor, what you hear is a flap controll servo motor which settles back to the position which was set before the unit or the ignition was switched off Quote Link to comment Share on other sites More sharing options...
Stretch 123 Posted November 16, 2016 Author Share Posted November 16, 2016 So relay then ? So new to landrovers Quote Link to comment Share on other sites More sharing options...
Stretch 123 Posted November 17, 2016 Author Share Posted November 17, 2016 Found out loose connection So cable tied together works fine now .thanks for every response Quote Link to comment Share on other sites More sharing options...
sierrafery Posted November 17, 2016 Share Posted November 17, 2016 Loose connection where? Quote Link to comment Share on other sites More sharing options...
Stretch 123 Posted November 17, 2016 Author Share Posted November 17, 2016 Side of the fan housing don't know what it does bit every time I held them together the fan worked Quote Link to comment Share on other sites More sharing options...
