FunkyMunky Posted November 22, 2016 Share Posted November 22, 2016 Hi folks, I have recently come into possession of a 'Superwinch S5000'. It's a bit tatty and needs a new rope and hook, but seems fine apart from that. My question is whether anyone has ever fitted these 'S series' winches to a Defender? Is it even possible, given that the drum is not central? If anyone has one of these fitted, then which bumper was used, as I see the mounting being the only restriction to fitting one? Stu. Quote Link to comment Share on other sites More sharing options...
dag019 Posted November 23, 2016 Share Posted November 23, 2016 Surely that is not powerful enough to use on the font of a defender? Quote Link to comment Share on other sites More sharing options...
qwakers Posted November 23, 2016 Share Posted November 23, 2016 a 5000lbs winch would be about as much use in a defender as a chocolate fireguard. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 23, 2016 Share Posted November 23, 2016 ....unless you are using it for something other than self recovery Stu, what's the intended use? Quote Link to comment Share on other sites More sharing options...
FunkyMunky Posted November 23, 2016 Author Share Posted November 23, 2016 So 5000lbs (2.2 ton) not enough? It would be for self-recovery (or recovering others!), so what pull would you suggest? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 23, 2016 Share Posted November 23, 2016 8-9,000lb is normally recommended for self and other recovery. Quote Link to comment Share on other sites More sharing options...
FunkyMunky Posted November 24, 2016 Author Share Posted November 24, 2016 Okay then...... have to keep my eyes peeled for something more suitable. I might pop this on the trailer then, or flog it to go towards something else. Cheers for the advice! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 24, 2016 Share Posted November 24, 2016 Funkymunky, you need to remember that the weight of your vehicle will be multiplied by the type of surface you're on, how stuck you are and gravity amongst other things. So your 5000lb winch would be perfectly capable of pulling you across smooth flat tarmac but add in the resistance of deep mud and an uphill pull and it will be overwhelmed. HTH Mo Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted November 24, 2016 Share Posted November 24, 2016 stalls at about 7.5k lbs - works well with a snatch block. Might just have enough grunt to get you out of trouble Very useful for dragging small logs, boats, annoying children, big dogs Quote Link to comment Share on other sites More sharing options...
FunkyMunky Posted November 26, 2016 Author Share Posted November 26, 2016 Okay guys, thanks for the advice. Going to keep looking for something more suitable but can't afford new. I might get lucky. Stu. Quote Link to comment Share on other sites More sharing options...
