pquin Posted December 10, 2016 Share Posted December 10, 2016 Hello All, I have a 2004 Freelander SE KV6 Automatic that is not feeling well. Both service lights are on. When driving, it will drive normally (quite well actually) for anywhere from 1 minute to 10 minutes, then a flashing F - 4 code on the LCD with the HDC warning lights lit up. The transmission goes into single speed limp mode. I've done a fair bit of googling regarding the problems which has lead me to suspect that it is an electrical / communications problem or a sensor problem that is bringing down the network. Suspects range from the brake switch to the ECU cooling fan to a dodgy hub speed sensor. I've hooked up a generic ODD II reader and retrieved the following list of codes: MIL DTC P1646 CAN link to auto gearbox ECU. Implausible signal/condition Technical Service Bulletins: There are currently no TSBs for P1646. Stored Codes P0222 Throttle/Pedal Position Sensor B Circuit Low Input P0500 Vehicle Speed Sensor A P0606 ECM / PCM Processor P1605 Internal EEPROM fault General fault P1627 engine overspeed.Implausible signal/condition P1646 CAN link to auto gearbox ECU.Implausible signal/condition Technical Service Bulletins: There are currently no TSBs for P1646. P1775 Gearbox Fault P1844 Engine RPM error flag set. Any thoughts on a good place to start. I'm a fairly competent mechanic and electrician with a good set of tools. I've started by installing a fresh battery and checked for obvious wire damage... Cheers, Paul in Victoria. Quote Link to comment Share on other sites More sharing options...
toastkid Posted December 12, 2016 Share Posted December 12, 2016 Have you had a look at the barrel connector: http://forum.lro.com/viewtopic.php?f=20&t=66004#p597701 Quote Link to comment Share on other sites More sharing options...
