enen Posted December 14, 2016 Share Posted December 14, 2016 I'm been benefiting from the posts here and thought id add my 2 cents. This may have been covered before. I have a gearbox with no vin, so probably a series 3? The transfer case also has no vin , so probably a 2A? I have a series 3 transfer case modified for the Ashcroft high ratio gears I removed the transfer case and installed the modified case . The gearbox seized up when i tightened the nut on the mainshaft Turned out the oil slinger was binding on the new case as the new case has a smaller hole. I guess the series 3 transfer case has a smaller oil slinger? Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 14, 2016 Share Posted December 14, 2016 I don't think so - as far as I know, there is absolutely no change between the SII suffix C unit until the end of SIII production other than the use of metric threads on the last couple of years (my 82 unit had metric threads). More likely is that the slinger has been slightly bent by being levered off the main shaft, as happened to mine, needing just a small fettling to fit correctly back inside the aperture. The dished part of the slinger does slide up and down its central collar; it's not brazed or welded on. Quote Link to comment Share on other sites More sharing options...
enen Posted December 15, 2016 Author Share Posted December 15, 2016 i just checked My original transfer case has an opening of approx 4.2" The series 3(??) case has an opening of 3.4" /so im unsure what i really am working with Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 15, 2016 Share Posted December 15, 2016 Could one of them be a 1-Ton transfer box casing? Quote Link to comment Share on other sites More sharing options...
enen Posted December 17, 2016 Author Share Posted December 17, 2016 it has a serial number Would that be a clue? 36132037D Quote Link to comment Share on other sites More sharing options...
