Hybrid_From_Hell Posted January 13, 2007 Share Posted January 13, 2007 A few peeps have asked me to add onto the forum the Magnecor lead lengths I had made. Heres a copy of the order I sent them, with the full specs and lengths These fit the coil packs when mounted on my coil pack mount, which Landy Andy is copying sorry evolving as per the EDIS8 thread... Maybe this could be a thread for useful extra info for Megasquirt and Megajolt installs ? If so add to it and TC will do the honours. My Starter for 10 : Coil Pack mount Pics : Leads fitted to coil packs : Magnecaor Leads order form with specs : Nige Quote Link to comment Share on other sites More sharing options...
TomG Posted January 13, 2007 Share Posted January 13, 2007 Nice bracket that. At the moment my coil packs are temporarily zip-tied to a pipe on the rocker cover and i have got my existing leads to work using 'pin extensions' from a set up old Zetec leads from trigger-wheels.com. I'm running MSnS wasted spark (no EDIS) (previously ran Weber 500 carb, coil+dizzy) I plan to make a coil pack bracket to bolt onto the rear of the heads (behind the plenum) and take lead measurements from there. Some pics of my triggerwheel bracket & chopped distributor: The VR bracket in the pic needed some trimming to clear the power steering belt My triggerwheel settings in Megatune: Set the timing to static last night and found it was 7 degrees too retarded (I had the VR sensor centred as best i could on the 5th tooth so don't understand why it's this far out). I'll try swapping the polarity of the VR sensor just incase. (I wired it as described in the MSnS manual) Luckily MS can correct for this in software This is only it's 2nd day running so still tweaking. Runs so smooth on MS and the VE autotune in Megatune is just awesome I'll post some more photos this afternoon, it's very much a temporary setup with chop-blocks and zip-ties so is not really drivable yet, i wanted to make sure my wiring was right before committing to solder & heatshrink! Quote Link to comment Share on other sites More sharing options...
TomG Posted January 14, 2007 Share Posted January 14, 2007 Some more pics for general info.. Revised VR mount to clear belt Running Megatune: Space Invaders! umm i mean VE Tuning Screen: Ain't Wi-Fi great Next job is tidying up the wiring and fitting the MS ECU in a cubby box (figured this would be the dryest place). Quote Link to comment Share on other sites More sharing options...
HoSS Posted January 14, 2007 Share Posted January 14, 2007 Tom i would be interested in your ignition map, when you think you have it. I would like to compare to mine (which i am a little uncertain about) Quote Link to comment Share on other sites More sharing options...
TomG Posted May 5, 2007 Share Posted May 5, 2007 Hoss, I ditched the spark map I was running and used the Excel calculator floating about, then did some more tweaking around idle and testing EVEME 1.0 UserRev: 1.00 UserComment: Date: 05-06-2007 Time: 00:07 Page 0 Scale 0.352000 Translate -28.400000 VE Table RPM Range [12] [ 0] = 5 [ 1] = 8 [ 2] = 10 [ 3] = 15 [ 4] = 20 [ 5] = 25 [ 6] = 28 [ 7] = 30 [ 8] = 35 [ 9] = 42 [ 10] = 50 [ 11] = 60 VE Table Load Range (MAP) [12] [ 0] = 20 [ 1] = 25 [ 2] = 30 [ 3] = 35 [ 4] = 40 [ 5] = 45 [ 6] = 50 [ 7] = 55 [ 8] = 60 [ 9] = 70 [ 10] = 80 [ 11] = 100 VE Table [ 12][ 12] [ 0] [ 1] [ 2] [ 3] [ 4] [ 5] [ 6] [ 7] [ 8] [ 9] [ 10] [ 11] [ 0] = 125 125 139 153 168 176 176 176 176 176 176 176 [ 1] = 122 122 136 148 162 176 176 176 176 176 176 176 [ 2] = 116 116 125 145 159 173 176 176 176 176 176 176 [ 3] = 111 114 122 142 156 168 176 176 176 176 176 176 [ 4] = 108 108 114 136 151 165 176 176 176 176 176 176 [ 5] = 105 105 111 131 145 162 176 176 176 176 176 176 [ 6] = 102 102 108 128 142 156 170 170 170 170 170 170 [ 7] = 97 97 102 125 139 153 165 165 165 165 165 165 [ 8] = 97 97 97 119 134 148 162 162 162 162 162 162 [ 9] = 88 88 88 111 125 139 153 153 153 153 153 153 [ 10] = 65 65 80 102 116 131 145 145 145 145 145 145 [ 11] = 57 57 65 99 114 114 128 128 128 128 128 128 Definitely better, seems a lot crisper at idle better response. I'd be interested in what maps other folk are running Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 10, 2009 Share Posted February 10, 2009 Well I've searched and searched but can't find it - someone had a ste of custom leads made up very nicely but cheaper than magnecors, and I'm jiggered if I can remember who it was and what the company was called anyone help? Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted February 10, 2009 Share Posted February 10, 2009 Well I've searched and searched but can't find it - someone had a ste of custom leads made up very nicely but cheaper than magnecors, and I'm jiggered if I can remember who it was and what the company was called anyone help? Was it this you were after? Roger Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted February 10, 2009 Share Posted February 10, 2009 Well I've searched and searched but can't find it - someone had a ste of custom leads made up very nicely but cheaper than magnecors, and I'm jiggered if I can remember who it was and what the company was called anyone help? I had a set of Mallorys in Gemima? They were cheaper than Magnecors and very good, but not very tidy as I guessed at the lengths I'd need months before doing the installation, and hadn't got round to tidying up when I sold her. They came from Lund Engines (good price, but they did take quite a while and a few chasing phone calls). Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 11, 2009 Share Posted February 11, 2009 Was it this you were after?Roger That's the puppy, ta very much! Quote Link to comment Share on other sites More sharing options...
stuck Posted May 29, 2009 Share Posted May 29, 2009 I know this is an old thread but I'd like to add the following: I think Magnecor (UK) must have learned something recently, Called them yesterday for a quote for a set of custom leads for my squirted V8, spoke to a very knowledgeable chap called Phil (think he's the MD) Was quoted quite a spendy price but when I asked when I could have them he said "Ehm... tomorrow?" Order placed! I have no connection with said company in any way, just thought I'd share my experience of good service. Mick. Quote Link to comment Share on other sites More sharing options...
