JST Posted October 3, 2005 Share Posted October 3, 2005 i have an '84 defender with the 4 spoke 90/110 style steering wheel. i am contemplating fitting a tdi style (i'll call it that for arguments sake) steering wheel that is one of the two spoke ones with the flat centre and black LR recessed badge over the bolt. Will this fit straight on??? I have heard mixed thoughts on this one. are def 200 and 300tdi steering wheels the same ro did the spline change around then? there is also the td5 style steering wheel - the one with the LR 'airbag' lump of plastic (yes i know some tdi have these as well but for simplicity i will call it a td5 one). i have heard this will go straight onto the spline but a tdi one won't. Whats the general conscensus then? And where or who might have one available? Link to comment Share on other sites More sharing options...
white90 Posted October 3, 2005 Share Posted October 3, 2005 Link to comment Share on other sites More sharing options...
Mark90 Posted October 3, 2005 Share Posted October 3, 2005 Tdi wheel won't fit, but one of the two types of td5 wheel will fit, I 'think' it's the one with the lump in the middle but not sure. I have found that an '89 RR wheel (2 spoke leather, hmm nice) will also fit in place of the early 4 spoke 90/110 wheel, just needs a bit of triming of either the plastic colum surround on the 90/110 column or the squishy foam on the back of the wheel itself as the two come into contact before the splines are fully on. Link to comment Share on other sites More sharing options...
fruity Posted October 3, 2005 Share Posted October 3, 2005 Tdi wheel won't fit, but one of the two types of td5 wheel will fit, I 'think' it's the one with the lump in the middle but not sure.I have found that an '89 RR wheel (2 spoke leather, hmm nice) will also fit in place of the early 4 spoke 90/110 wheel, just needs a bit of triming of either the plastic colum surround on the 90/110 column or the squishy foam on the back of the wheel itself as the two come into contact before the splines are fully on. Wot Mark said - I did exactly the same. BTW, you may also have to get creative with the stepped disk on the back of the wheel if you want to keep self canceling indicators! Link to comment Share on other sites More sharing options...
BogMonster Posted October 4, 2005 Share Posted October 4, 2005 there is also the td5 style steering wheel - the one with the LR 'airbag' lump of plastic (yes i know some tdi have these as well but for simplicity i will call it a td5 one). i have heard this will go straight onto the spline but a tdi one won't. I understand the Td5 type "airbag without an airbag" wheel will fit straight on to the splines in place of the original 4 spoke wheel fitted to earlier 90/110. But a Tdi type one (with the dig-outable LR badge in the middle as fitted to all mid 1990s 300Tdis) will not - that is a different spline which is the same as a Rover Metro wheel, because somebody I know with an older 300Tdi has one of those fitted, a nice modification for a smaller wheel but it won't fit yours. The "airbag" wheel is fitted to some new vehicles (e g Tdi 90 Station Wagons like mine which is 2004, and I think most or all Td5s) and the "old" type wheel is fitted to some others (such as new Tdi engined 110 Station Wagons). Quite why LR choose to have 2 different types of steering column and two different types of steering wheel on vehicles being produced simultaneously on the same production line is one of life's unanswerable questions.... Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 4, 2005 Share Posted October 4, 2005 Yep, know the "What steering wheel should I fit other than the revolting plastic one" problem well ! Looked at many of the aftermarket ones, those I liked were silly money, ................those that weren't were, er...horrible ! TDi stuff doesn't fit, BUT, a Late TD5 CSW wheel, such as this DOES... It (for some seriously odd reason) goes back to the earlier spline style, bolts on as tho it was originally made for it ! (and mines C Plate 1985) And thats why I have one !.... Know what your going to be looking for at Old Sodbury then Nige Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 4, 2005 Share Posted October 4, 2005 by that i didn't mean the fuel tank was off a l/weight Perish the thought, ...................... Is this "Ali" tank in some perverse way trying to compensate for the small 'atomic power station' (your battery) you carry on the same side ? Nige Link to comment Share on other sites More sharing options...
D9OSV Posted October 4, 2005 Share Posted October 4, 2005 Hello, 90/110 circa '84 to 90' has the same steering shaft as a def td5 csw. Def90/110 circa 90' to present are all the same apart from TD5 csw which is of course the same earlier..... Understand...?????? Thought not As for disco and range?????? F**k knows? Jim Link to comment Share on other sites More sharing options...
jules Posted October 4, 2005 Share Posted October 4, 2005 White 90 (tony) I though I was the only one to have a MOMO course wheel fitted there nice to use arnt they but not cheep yours looks a little newer than mine. Jules Link to comment Share on other sites More sharing options...
Divster Posted October 4, 2005 Share Posted October 4, 2005 White 90, Mmmmmmmmm momo, very nice. Where from and how much??? Also, how the hell do you get your cab that clean Dave Link to comment Share on other sites More sharing options...
white90 Posted October 4, 2005 Share Posted October 4, 2005 White 90,Mmmmmmmmm momo, very nice. Where from and how much??? Also, how the hell do you get your cab that clean Dave Demon tweeks for the wheel £170 boss was £25 normally £40 Divster I never take it off road just a tarmac vehicle I know it looks dreadfull look at that tatty seat tut tut I have had new covers since.... Link to comment Share on other sites More sharing options...
SiWhite Posted October 4, 2005 Share Posted October 4, 2005 I've got a MOMO wheel as well, and I love it! It was originally on my Mazda sports car before our crash (God rest her soul) and was stripped before the Insurance man got his hands on it! Not sure I paid as much as Tony, I think mine was about £120 plus the boss. Link to comment Share on other sites More sharing options...
D9OSV Posted October 5, 2005 Share Posted October 5, 2005 Have Momo wheels on the shelf for around£90 +vat Boss is around £35 If anyone is intrested. We also do a custom bad adaptor to keep the steering wheel in the same position as a standard wheel, rather than most bosses that bring the steering wheel much closer to the driver. Sorry don't usually do the "Plug" thing...... Jim Link to comment Share on other sites More sharing options...
jules Posted October 5, 2005 Share Posted October 5, 2005 DS90SV I was going to say I got mine from Halfords for £99 with a special offer free boss once they ordered it in. Link to comment Share on other sites More sharing options...
Niall_CSK Posted October 5, 2005 Share Posted October 5, 2005 If my memory serves me correctly, long time since I had a series, the splines are the same on all the Rover vehicles up to the 90's maybe even later. If that is the case with the 110, can't see them changing it, then SD1, Montego etc should also fit without having to use an adaptor boss or if you are on a budget. Link to comment Share on other sites More sharing options...
Neil Marshall Posted October 5, 2005 Share Posted October 5, 2005 You can pick up a good used Momo leather wheel on Ebay for under £30 - masses of them. Mine is a 14" wheel and makes turning in much quicker/driving generally more comfortable. I have a run out 300TDi Defender - as it's a CSW it has the RR Classic steering column and I bought the Momo hub for £35 delivered. [i was told that Halfords sell a cheaper range of bosses and they must include the RR Classic.] My original wheel was the one that looks like it has an airbag - the wheel shape is an adaption of a run-out Classic wheel. The Momo boss only brings the wheel forward by 3/4"....surprisingly, made the driving position more comfortable [i am 6'2"]. I had to trim 1/4" from the front of the steering column shroud. Finally, there's a guy on Ebay who sells steering wheel pullers for under £10 - brilliant kit and highly desirable. I thought that the steering column changed when the Defender got a disc-brake rear axle. Neil Link to comment Share on other sites More sharing options...
Mark90 Posted October 5, 2005 Share Posted October 5, 2005 If my memory serves me correctly, long time since I had a series, the splines are the same on all the Rover vehicles up to the 90's maybe even later.If that is the case with the 110, can't see them changing it, then SD1, Montego etc should also fit without having to use an adaptor boss or if you are on a budget. Tdi two spoke wheels are the same as the series ones, but these are different to the 90/110 4 spoke wheels. Link to comment Share on other sites More sharing options...
McS Posted October 5, 2005 Share Posted October 5, 2005 Have u any pics of the wheel Jim? McS Link to comment Share on other sites More sharing options...
LR90 Posted October 5, 2005 Share Posted October 5, 2005 Finally, there's a guy on Ebay who sells steering wheel pullers for under £10 - brilliant kit and highly desirable. I used to just remove the nut and sit there thumping the wheel from behind with my fists. Thump, thump,... you know that sort of here's a Nige moment coming Thump, thump... Hit it harder.. Thump, thump... bang.. that's the bang of the now free and very fast moving wheel making contact with my face Now I always slacken but leave the nut in place Link to comment Share on other sites More sharing options...
white90 Posted October 5, 2005 Share Posted October 5, 2005 Leave nut on after undoing it a bit holding steering wheel at 3 and 9 oclock position and rock it forwards and back, never failed yet to remove one. Link to comment Share on other sites More sharing options...
Paul Posted October 5, 2005 Share Posted October 5, 2005 Just for the sake of some contrast, I used a wheel from Issotta instead of Momo. Momo's were just too expensive, and the bosses too hard to get in Australia, Issotta had them on the shelf. Link to comment Share on other sites More sharing options...
western Posted January 30, 2006 Share Posted January 30, 2006 Swapped my old 4 spoke wheel for a new Td5 2 spoke type, leather covering as well, have a read Here Link to comment Share on other sites More sharing options...
