ibexman Posted October 7, 2005 Share Posted October 7, 2005 My discs on the ibex are due for a change , are there any straight swaps for uprated discs ie drilled or vented would ther be any marked improvement in braking?????? Quote Link to comment Share on other sites More sharing options...
white90 Posted October 7, 2005 Share Posted October 7, 2005 My discs on the ibex are due for a change , are there any straight swaps for uprated discs ie drilled or vented would ther be any marked improvement in braking?????? Vented will require wider calipers drilled will just fill with mud I wouldn't bother personally Quote Link to comment Share on other sites More sharing options...
ibexman Posted October 7, 2005 Author Share Posted October 7, 2005 Vented will require wider calipersdrilled will just fill with mud I wouldn't bother personally Hmmmm never thougt of that cheers Tony Quote Link to comment Share on other sites More sharing options...
white90 Posted October 7, 2005 Share Posted October 7, 2005 Hmmmm never thougt of that cheers Tony pic Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 7, 2005 Share Posted October 7, 2005 My discs on the ibex are due for a change , are there any straight swaps for uprated discs ie drilled or vented would ther be any marked improvement in braking?????? Yep, I run vented drilled vented slotted on the front and slotted rears, braking is immensely more powerfull. But, if I was doing it again I would not have them drilled, as the mud does get in dry and can act as a grinding paste, vented and slotted is fine, the mud comes out of the slots most of the time, go also for harder pads as they will last longer and can take it HTH Nige Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted October 7, 2005 Share Posted October 7, 2005 Drilling is to reduce rotating mass of the disc, venting is to improve cooling of the disc to offset brake fade under prolonged or intensive use. Drilling is not done to improve airflow apparently - I think this is a common misconception. If you are not trying to reduce the mass of your axle (either in terms of raw weight, or in terms of rotating inertia), nor suffering from brake fade due to the discs becoming overheated, then you don't need either as far as I understand it? I've been looking into brakes, and I got all this from the manufacturers, so don't shoot the messenger! Makes sense to me though... Besides for offroad I've heard it said a lot that carp gets stuck in the holes (like stones or whatever) and screws the pads if you use drilled discs. Al. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted October 7, 2005 Share Posted October 7, 2005 Yep,I run vented drilled vented slotted on the front and slotted rears. HTH Nige Nige's way off keeping the weight down as well ! Quote Link to comment Share on other sites More sharing options...
JST Posted October 7, 2005 Share Posted October 7, 2005 do the current ones do the job? if so i would stick with them, cheaper, and you know how you stand with them and getting spares/replacements etc. i obviosuly dont know the ibex spec but i am guessing its running off road tyres. therefore they are prob your current limiting factor on stopping. if the current setup locks the wheels up quickly now then surely discs that give better stopping ability will just achieve the same aim but a fraction of a second quicker. (would you notice this? i dont know) granted for repeated hard breaking then sloted and vented are def the way fwd. you could go for a set of road tyres........................ Quote Link to comment Share on other sites More sharing options...
ibexman Posted October 7, 2005 Author Share Posted October 7, 2005 do the current ones do the job? if so i would stick with them, cheaper, and you know how you stand with them and getting spares/replacements etc. i obviosuly dont know the ibex spec but i am guessing its running off road tyres. therefore they are prob your current limiting factor on stopping.if the current setup locks the wheels up quickly now then surely discs that give better stopping ability will just achieve the same aim but a fraction of a second quicker. (would you notice this? i dont know) granted for repeated hard breaking then sloted and vented are def the way fwd. you could go for a set of road tyres........................ Road tyres???? come on dont be silly now Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 7, 2005 Share Posted October 7, 2005 pic "You are not logged in or you do not have permission to access this page. This could be due to one of several reasons: You are not logged in. Fill in the form at the bottom of this page and try again. You may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system? If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation. " Quote Link to comment Share on other sites More sharing options...
siggy Posted October 8, 2005 Share Posted October 8, 2005 Boggy this is what you missed hope that helps Quote Link to comment Share on other sites More sharing options...
jules Posted October 8, 2005 Share Posted October 8, 2005 As you may know I Race stuff 1.8 160 bhp 1.4 ton rally freelander drilled & groved disc with EBC pads massive improvment very very noticable 2.0 200 bhp 1.6 ton Ex dakar Freelander drilled & vented & groved with EBC pads masive improvmet very very noticable TD5 Dicso Es stock Drill & vented & groved and EBC pads allround big improvment when towing or if the car is loaded otherwise there a bit better. Big 90 4.2 will be fitting them before the next MOT Mud blocking them up, well yes but the mud gets hot drys and shrinks then falls out as there is a fair amount of sentrofugal force remember. after a race meeting I have to clean everything and only about 20% of the disc will have mud in it, if that I have them and would recomend them the pads make a big difrance too and last longer I find Put it this way the two freelanders sets were given to me to test by Bearmach but I then bought a full set for the disco Julian Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 8, 2005 Share Posted October 8, 2005 Boggy "Boggy"? you after a thick ear or summat? come here and say that.... Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 8, 2005 Share Posted October 8, 2005 Surely you only need vented / drilled / slotted if you are currently suffering from brake fade. This would normally occur under high speed conditions with a lot of hard braking - which is why Jules rates then so highly. If you are not in to speed events and your brakes perform adequately then stick to what you have. The most I would do would be to upgrade to vented discs. Drilling and slotting is really not necessary IMHO unless you race. Additionally, you will be replacing brake pads far more frequently if you drill / slot. Just my 2p. Oh and to quote Siggy: "Boggy" ROFPMSL Quote Link to comment Share on other sites More sharing options...
jules Posted October 8, 2005 Share Posted October 8, 2005 Your right Just get better pads winch comps don't involve enough speed to warent drilled and groved but the 90 runs EBC (there are other make as good I would assum) that made a big improment and they are still going strong. I only fitted them cos I couldn't be bothered to fit a new servo which was the route of my braking problems on my 90. Quote Link to comment Share on other sites More sharing options...
siggy Posted October 8, 2005 Share Posted October 8, 2005 "Boggy"?you after a thick ear or summat? come here and say that.... OK I setting off walking to you now so I'll see you in erm six years or so Quote Link to comment Share on other sites More sharing options...
western Posted October 8, 2005 Share Posted October 8, 2005 Siggy, don't forget your wetsuit & snorkel Quote Link to comment Share on other sites More sharing options...
siggy Posted October 8, 2005 Share Posted October 8, 2005 Dag namit got as far as huntingdon will have to turn back and get them so that'll be 6.5 years (ish) Quote Link to comment Share on other sites More sharing options...
