VDO gauge info
300 Tdi:
350-104 2 1/16 80 PSI Elec. engine pressure gauge Vision $25.75
360-006 Pressure Sender: 0-80 PSI/5 Bar - M10x1K - 7.0 PSI $28.37
333-156 2 1/16 4,000 RPM Tachometer Vision $74.81
310-105 2 1/16 250F Elec. engine temp gauge Vision $25.55
323-095 Temperature Sender: 250F/120C - 1/8-27 NPT - $7.31
310-153 2 1/16 250F-1650F Pyrometer (EGT) Vision Marine $153.75
1994 3.9 V8
323-417 Temperature Sender: 250F/120C - M16x1.5 - $18.82
360-009 Pressure Sender, 0-80PSI/5 Bar - 1/8-27 NPT $33.34
5-1/8 F50G-S Adapter Fitting: Parker Hydraulics - $11
All these parts were sourced from eguages.com, which is a US company, so all the readings are psi, fahrenheit, etc. Also, these gauges have words like "temp" "pressure" etc, because its a US requirement to have actual words. We're not smart enough for icons. The senders are the really important stuff though, the sizes being the main challenge. I've personally used each of these parts and can vouch for the correcness of the list.
Note that an old oil pressure sender can have the center knocked out and a bung can be welded on to create a cheap adapter.
