3.5 V8 Flapper system Diagnostic Manual
Hi All,
Usefull for those hard to work out 3.5 Rover V8 EFI "Flapper System" Faults.
Before you dive into this also check :
GENUINE Dizzy and Rotor Arm
Decent Leads - not much beats a Genuine set to be honest
NGK BP6RES PLugs NOT Champion esp
Timing light check, does it advance also when you rev up
Coil - NOT an Intermotor one :)
Remove 9th Injector
and in the manual is a 'ByPass bodge' to test the CTS .......which pops and fails for a pastime
TPS at .325 and no huge dead zones
The, after the above and only then go into the 2 manuals :
Rover_3.5EFI_System_Information.pdf
Rover_3.5EFI_Test_Process.pdf
Thought I had done this previosly but must have forgeotten :)
Hope this helps many on LR4x4
Nige
