Tubed and Tubeless Wolf Rims
Gromit
Don't know if this is of any use to anyone, but I'd have liked to have known this info about a month ago.
Here's how to spot a tubed and tubeless wolf rim. The tubeless one is stamped ANR4583 TUBELESS, as it's genuine.
The tubed one is pattern and isn't stamped with anything (hence much confusion :angry: ).
The main difference is that the tubeless one on the left has a defined bead seat, where as the tubed one does not:
If there's a tyre on the rim, then the bead seat can be spotted from the outside:
Tubeless:
Tubed:
It can also (more easily) be spotted from the inside of the rim:
Tubeless:
Tubed:
HTH, and if you already knew how to suck eggs....... :)
  • Thanks 1
  • 10 years later...
