roguevogue Posted November 2, 2005 Share Posted November 2, 2005 After a quick coat of paint. a trial fitting of the arms after fitting the poly bushes I picked up at Sodbury for £2. first fitting to the chassis. brake pipes fitted. and finally testing the articulation before setting the height for the shock mounts. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 2, 2005 Share Posted November 2, 2005 Nick, Very Very Nice.... 'cept the sticker in the 4th photo...... .....disgraceful Nige Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 2, 2005 Share Posted November 2, 2005 Too right - bluddy traitor! Les. Quote Link to comment Share on other sites More sharing options...
tuko Posted November 3, 2005 Share Posted November 3, 2005 Impressive 3 link setup! B) Also the way that the brake lines have been placed behind the axles, running along the radium arms. Well thought out setup. I'll certainly be watching closely, to see how well it performs, both on the road and the trials. Cheers, Todd. Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 3, 2005 Share Posted November 3, 2005 Nick, last picture, your tyre is on the wrong way round Quote Link to comment Share on other sites More sharing options...
02GF74 Posted November 3, 2005 Share Posted November 3, 2005 Joseph and his technicoloured dream rangie I was ok with it until I saw the yellow calipers... No doubt this colour coding will allow repair by someone else at a distance, you calling them on the mobile saying undo the orange bit on the right etc... (You really should read up about user interface design and study the chapter on the use of colours). Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 3, 2005 Share Posted November 3, 2005 J White will approve of the yellow caliper Quote Link to comment Share on other sites More sharing options...
maverick Posted November 3, 2005 Share Posted November 3, 2005 very nice piece of fabrication and well thought out .might be a little hard with poly bushing but will reduce the anti dive . what triangulation depthyou got on the axle Quote Link to comment Share on other sites More sharing options...
roguevogue Posted November 3, 2005 Author Share Posted November 3, 2005 Made the top shock mounting last night, painted it blue , the colours are a bit of fun really, to aid in the explanation of how it works from photos. As for the yellow calipers, all the best ones are yellow, I figured there must be some benefit to the colour, heat disipation or something. At the end of the day the colour will be brown all over so who cares. Finally, Tonk, haven't you got anything better to do? You think this is a picture of the front of my Rangie don't you. Quote Link to comment Share on other sites More sharing options...
SteveG Posted November 3, 2005 Share Posted November 3, 2005 Hi Nick I like your idea of how to fit radius arms to the chassis. Surprised that anyone hasn't thought of this before. Steve Quote Link to comment Share on other sites More sharing options...
roguevogue Posted November 3, 2005 Author Share Posted November 3, 2005 It's something i've thought quite a long time about, all the other solutions have their limitations, as does mine, but this is the easiest, and critically cheapest, solution. On the money side of things, i've spent more on bushes, brake pipe, pads, nuts and pistons, nuts and bolts and grease nipples etc. to build this than I spent on the original build, including winch!! Scarey. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted November 3, 2005 Share Posted November 3, 2005 On the money side of things, i've spent more on bushes, brake pipe, pads, nuts and pistons, nuts and bolts and grease nipples etc. to build this than I spent on the original build, including winch!! Scarey. Bloody cheque book off roaders Quote Link to comment Share on other sites More sharing options...
will_warne Posted November 3, 2005 Share Posted November 3, 2005 Bloody nice, Nick!!! That's a very good, well thought out set up. Did you think about having a single upper link rather than a single lower link or were there sump issues? I like what you've done with the brake lines; I hadn't thought of that. I think I'll have to use that when I multilink both ends Quote Link to comment Share on other sites More sharing options...
MogLite Posted November 4, 2005 Share Posted November 4, 2005 Good set of piccies there rogue. Nice one. But with all that work, you should have thrown a portal axle in there Are they adjustable in length ? Hence the different colour - if so what did you use for a thread ? Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 4, 2005 Share Posted November 4, 2005 all that bling bling paintwork and u leave the axle in primer Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 4, 2005 Share Posted November 4, 2005 Tonk, Nah, think is just one the the "In Vogue Shades" from the latest colour chart he has been working through ..... Nick, are yoiu going to call your truck "Dulux" ? Quote Link to comment Share on other sites More sharing options...
GBMUD Posted November 4, 2005 Share Posted November 4, 2005 Nick, are yoiu going to call your truck "Dulux" ? Nah, Dyson. Chris Quote Link to comment Share on other sites More sharing options...
roguevogue Posted November 4, 2005 Author Share Posted November 4, 2005 Bloody nice, Nick!!! That's a very good, well thought out set up. Did you think about having a single upper link rather than a single lower link or were there sump issues? I like what you've done with the brake lines; I hadn't thought of that. I think I'll have to use that when I multilink both ends Quite right, the sump is in the way of putting the third link at the top. Good set of piccies there rogue. Nice one.But with all that work, you should have thrown a portal axle in there Are they adjustable in length ? Hence the different colour - if so what did you use for a thread ? They are adjustable in length I suppose but thats not why the thread is there. The thread is M30, primarily because I bought 3 M30 taps on ebay for £9. one unused spiral flute which would cost about £60 on its own from our engineering supplies place. I used an M30 bolt for the male thread. all that bling bling paintwork and u leave the axle in primer Not primer just grey eggshell finish, it's in vogue this autumn you know. Tonk,Nah, think is just one the the "In Vogue Shades" from the latest colour chart he has been working through ..... Nick, are yoiu going to call your truck "Dulux" ? Two more colours tonight, on the track rod (silver) and steering damper (black with metallic over laquer) Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted November 4, 2005 Share Posted November 4, 2005 Nick - very tidy piece of fabrication. What're the two lugs that stick out forwards from the swivel bolts? Quote Link to comment Share on other sites More sharing options...
white90 Posted November 4, 2005 Share Posted November 4, 2005 Very nice work Nick What front prop will you be running? Quote Link to comment Share on other sites More sharing options...
Mark90 Posted November 4, 2005 Share Posted November 4, 2005 Nick - very tidy piece of fabrication. What're the two lugs that stick out forwards from the swivel bolts? My money's on shock mounts. Quote Link to comment Share on other sites More sharing options...
roguevogue Posted November 4, 2005 Author Share Posted November 4, 2005 Nick - very tidy piece of fabrication. What're the two lugs that stick out forwards from the swivel bolts? Lower shock mounting, more pictures along soon. Very nice work NickWhat front prop will you be running? Standard front prop, the axle doesn't move that much lower than standard and the diff follows the gearbox output now. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted November 4, 2005 Share Posted November 4, 2005 Given that the lower shock mounts are just below the steering box holes are you just bolting the top mounts on are is it a more sunstantial welded affair? And more importantly, what colour will they be. Quote Link to comment Share on other sites More sharing options...
roguevogue Posted November 4, 2005 Author Share Posted November 4, 2005 Given that the lower shock mounts are just below the steering box holes are you just bolting the top mounts on are is it a more sunstantial welded affair?And more importantly, what colour will they be. The top mounts bolt onto the same place as standard ones and yes they are a "welded affair". They are blue, there may be pictures of them tomorow night. Quote Link to comment Share on other sites More sharing options...
LR90 Posted November 4, 2005 Share Posted November 4, 2005 Your truck just keeps getting better Nick. Nice one What shocks lengths do you expect to run and will you retain the springs or let them dislocate? Quote Link to comment Share on other sites More sharing options...
