bazza Posted November 29, 2007 Share Posted November 29, 2007 Are the temp gauge sender units in the 200tdi different for the disco and RRC? i fitted a 200tdi into my RRC (replacing the 2.5VM) and the only thing that aint working is the temp gauge, it works fine when earthed out though and the temp gauge worked when the engine was in the disco chassis. im guessing they work at different reseistance? Baz Quote Link to comment Share on other sites More sharing options...
ciderman Posted November 29, 2007 Share Posted November 29, 2007 I recon they must be . I fitted a 200tdi Disco lump into a 90 and had to change the sender to get an accurate reading on the gauge . Try a sender from a RRC 200 tdi . Quote Link to comment Share on other sites More sharing options...
western Posted November 29, 2007 Share Posted November 29, 2007 (edited) Defender 200Tdi 11L engines uses PRC8593 Discovery 200Tdi 12L engines either PRC8001 -- Orange or PRC9917 -- Green, Gulf states vehicle use PRC9942 -- no colour detailed RRC 200Tdi 14L engines use AMR1712 no colour code detailed. that should help fitting any 200Tdi that isn't a correct Defender high mounted turbo type [see photo below- taken from standing above looking down] in a 90/110/Defender fit sender PRC8593 to make the temp gauge read correctly. Edited November 30, 2007 by western Quote Link to comment Share on other sites More sharing options...
miketomcat Posted November 30, 2007 Share Posted November 30, 2007 i've put a RRC 200tdi in a tomcat (disco) and the gauge now reads at the quater mark instead of the half mark did think i had the wrong termostat but the heater seemed fine what your saying now makes sence mike Quote Link to comment Share on other sites More sharing options...
bazza Posted November 30, 2007 Author Share Posted November 30, 2007 i've put a RRC 200tdi in a tomcat (disco) and the gauge now reads at the quater mark instead of the half mark did think i had the wrong termostat but the heater seemed fine what your saying now makes sence mike Mike, I have the sender for a Disco in my 200tdi but need a RRC sender and it seems you need the disco one and have a RRC one, fancy a swap? i'm guessing yours is the tomcat around Saxon? if so i work next door in the Oil Spill base. Baz Quote Link to comment Share on other sites More sharing options...
