BadBob Posted March 4, 2008 Share Posted March 4, 2008 Hi all can anybody tell me if is poss to change front out put bearing in transfer box on 93 200tdi defender in situ I seem to have a viberation that I thought was prop but tested it and its fine but noticed if you give the flange a shake when prop was off there is some play so I assume the bearing has worn thanks Quote Link to comment Share on other sites More sharing options...
Lars L Posted March 4, 2008 Share Posted March 4, 2008 http://www.discoweb.org/tcasebearing/index.htm Haven't done this myself... Quote Link to comment Share on other sites More sharing options...
BadBob Posted March 4, 2008 Author Share Posted March 4, 2008 http://www.discoweb.org/tcasebearing/index.htmHaven't done this myself... Thanks for link doesnt look to hard apart from removing the actual bearing Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 4, 2008 Share Posted March 4, 2008 The front output bearing on the transfer case is supposed to have some play in it - it's a different type of bearing to the rear one. The movement limit is 8mm (I think) Les. Quote Link to comment Share on other sites More sharing options...
white90 Posted March 4, 2008 Share Posted March 4, 2008 Roller type bearing instead of Tapered 4mm play is normal Quote Link to comment Share on other sites More sharing options...
BadBob Posted March 5, 2008 Author Share Posted March 5, 2008 The front output bearing on the transfer case is supposed to have some play in it - it's a different type of bearing to the rear one. The movement limit is 8mm (I think)Les. Thanks Les & White 90 sounds like I had better looked elsewhere for my vibe also I would like to take this opportunity to tell you that I spend hours reading you excellent and very informative posts with super pictures far better than haynes manuals best regards Michael Quote Link to comment Share on other sites More sharing options...
