tonycougar Posted April 4, 2008 Share Posted April 4, 2008 Does anyone know if its possible to replace the front output shaft bearing with the box in situ? I don't fancy taking the box out to do it. I know Les has produced a how to for the rear one, but the front looks a bit more complicated. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted April 4, 2008 Share Posted April 4, 2008 This question has been asked a few times before on this forum. Last time in this thread: http://forums.lr4x4.com/index.php?showtopic=23690 Quote Link to comment Share on other sites More sharing options...
gus Posted April 4, 2008 Share Posted April 4, 2008 Does anyone know if its possible to replace the front output shaft bearing with the box in situ? I don't fancy taking the box out to do it. I know Les has produced a how to for the rear one, but the front looks a bit more complicated. Of course it is possible. It's more easier than rear. Quote Link to comment Share on other sites More sharing options...
tonycougar Posted April 4, 2008 Author Share Posted April 4, 2008 Thanks fellas, thought I'd seen something somewhere. Quote Link to comment Share on other sites More sharing options...
tonycougar Posted April 4, 2008 Author Share Posted April 4, 2008 Thanks fellas, thought I'd seen something somewhere. Gus, It looks like you have removed the whole ouput shaft to do it. Is that what you did? Does it go back in easy enough? Quote Link to comment Share on other sites More sharing options...
gus Posted April 6, 2008 Share Posted April 6, 2008 Gus,It looks like you have removed the whole ouput shaft to do it. Is that what you did? Does it go back in easy enough? Yes tonycougar, the bearing is fixed to the shaft, not to tranfer. You can remove it without problem pulling, like you can see in the photo. It is very easy. Quote Link to comment Share on other sites More sharing options...
tonycougar Posted April 6, 2008 Author Share Posted April 6, 2008 Yes tonycougar, the bearing is fixed to the shaft, not to tranfer. You can remove it without problem pulling, like you can see in the photo. It is very easy. I have also been told that I need to shim the bearings too. Would I need to buy new shims or just use the original ones and replace the oil seal. Quote Link to comment Share on other sites More sharing options...
tonycougar Posted April 8, 2008 Author Share Posted April 8, 2008 I have also been told that I need to shim the bearings too. Would I need to buy new shims or just use the original ones and replace the oil seal. And what about setting up the pre-load? The manual says you need to wrap string around a shaft select high or low gear then check the pre-load with a spring balance (This is all with the box on the bench). Quote Link to comment Share on other sites More sharing options...
TomG Posted April 13, 2008 Share Posted April 13, 2008 Gus - excellent writeup with the photos! just about to do mine. Mods - Could this be one for the tech archive? Quote Link to comment Share on other sites More sharing options...
Andy J Posted May 19, 2008 Share Posted May 19, 2008 Gus - excellent writeup with the photos! just about to do mine.Mods - Could this be one for the tech archive? Hi chaps, im interested in seeing this but the pictures dont seem to come through (just red crosses) - any chance this can be fixed? Thanks Andy 1 Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted April 11, 2010 Share Posted April 11, 2010 any chance you have some pictures on how to change the rear innner taper bearing. My thread is here. http://forums.lr4x4.com/index.php?showtopic=52813&st=100 Thanks Quote Link to comment Share on other sites More sharing options...
Marco Posted April 11, 2010 Share Posted April 11, 2010 Yes tonycougar, the bearing is fixed to the shaft, not to tranfer. You can remove it without problem pulling, like you can see in the photo. It is very easy. Thanks Gus, very useful post. Just a question, do you have any images of the rear output shaft and bearing + speedo drive? I've dismantled mine 5 Months ago and am now in the process of fitting back together. For some reason the speedo drive is a loose fit on the shaft + can slide for about one cm. Should it be like that y/n? Cheers Marco Quote Link to comment Share on other sites More sharing options...
prochy.janek Posted June 4, 2010 Share Posted June 4, 2010 Hi guys, plese can somebody number of this bearing??? Thanks Quote Link to comment Share on other sites More sharing options...
western Posted June 4, 2010 Share Posted June 4, 2010 Hi guys, plese can somebody number of this bearing??? Thanks STC1130 Item 9, parts book page 439 Quote Link to comment Share on other sites More sharing options...
prochy.janek Posted June 5, 2010 Share Posted June 5, 2010 STC1130 Item 9, parts book page 439 Thanks, I’m but didn't think part number. Needed would know proportion for reservation SKF.... Quote Link to comment Share on other sites More sharing options...
western Posted June 5, 2010 Share Posted June 5, 2010 most bearings have their makers part number stamped or engraved into the edge of the outer bearing race, Quote Link to comment Share on other sites More sharing options...
prochy.janek Posted June 6, 2010 Share Posted June 6, 2010 most bearings have their makers part number stamped or engraved into the edge of the outer bearing race, Yes it I know, this very issue would needed know. Thanks Quote Link to comment Share on other sites More sharing options...
prochy.janek Posted June 8, 2010 Share Posted June 8, 2010 Bearing number is: SKF 6207 price cca 3GBP Quote Link to comment Share on other sites More sharing options...
DavidW Posted September 13, 2017 Share Posted September 13, 2017 Does anyone know where I might find a copy of the how to photos missing from this thread? Thanks David Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted September 13, 2017 Share Posted September 13, 2017 Here's some of my photos from when I did it: 2 Quote Link to comment Share on other sites More sharing options...
DavidW Posted September 16, 2017 Share Posted September 16, 2017 Dailysleaze, thanks for posting the photos. It would be good if these could somehow get linked back the technical archive post to make that thread useful again? Quote Link to comment Share on other sites More sharing options...
