Hybrid_From_Hell Posted May 19, 2008 Share Posted May 19, 2008 Hi all, Have been helping a fellow 'V8 nut' sort out a engine quirk, as a result I had to 'dig this up', .....and thought it would be worth popping up here. Many Rover V8 owners are used to having to tighten up a Head in a set order bolt wise, .... many are equally unaware of this also being the case on a Inlet Manifold. Enclosed is a piccie for both For a TIN valley gasket 25-30 Ft Lbs (in 2 stages 20 and then either 25 or 30) For a COMPOSITE valley gasket 40 Ft Lbs (in 3 stages 15 then 35 then 40) Thought this may be useful Nige Quote Link to comment Share on other sites More sharing options...
