mr_pr Posted January 11, 2006 Share Posted January 11, 2006 Hi Guys im new here but been a member on various other LR forums for a while now! Quick Question, does any one know if this Rev Gauge VDO Vision tacho will work with a 200Tdi. Stadard alternator i presume!! Cheers Guys Quote Link to comment Share on other sites More sharing options...
western Posted January 11, 2006 Share Posted January 11, 2006 (edited) Should be, IIRC the LR rev counters are actually VDO units, mine is connect a signal cable to the 'W' terminal on the back of the alternator [100amp Marelli on my 200Tdi] If your Alternator doesn't have a 'W' terminal a good auto electrician should be able to fit a suitable connector for you to use. connect the rev counter gauge illumination to the existing gauges. read THIS Edited January 11, 2006 by western Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 21, 2006 Share Posted January 21, 2006 Should be, IIRC the LR rev counters are actually VDO units, mine is connect a signal cable to the 'W' terminal on the back of the alternator [100amp Marelli on my 200Tdi] If your Alternator doesn't have a 'W' terminal a good auto electrician should be able to fit a suitable connector for you to use. connect the rev counter gauge illumination to the existing gauges. read THIS Yes, I have one, they are fully adjustable. If you do not have a tach lead on the alternator you just need to tap into one of the raw AC signals from the stator. This picture is my alternator. The blue wire goes to the tach. Any of the 3 main posts will work. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 21, 2006 Share Posted January 21, 2006 Hang on, I did not check your link. That lists a 3.5" unit. The standard gauges are 52 mm (2-1/16"), so to fit that one you'd need an alternate location. Quote Link to comment Share on other sites More sharing options...
