tommac Posted November 13, 2008 Share Posted November 13, 2008 Hi all, Going to have a bash at checking and adjusting the tappets on the defender 300tdi at the weekend. Anyone Got any information on what the clearances should be? Any tips? Cheers in advance. Tom Quote Link to comment Share on other sites More sharing options...
white90 Posted November 13, 2008 Share Posted November 13, 2008 Here you go Also replace the Rocker Gasket Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted November 13, 2008 Share Posted November 13, 2008 And if you find a clearance of nearly 1mm, then the valve stem cap will have broken or fallen off. Best to replace them because they save a lot of wear on the rockers. Check the tightness of the bolts holding down the rocker shaft, if they come loose the shaft will break. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 13, 2008 Share Posted November 13, 2008 .2 mm clearance, he said knowledgeably Mo Quote Link to comment Share on other sites More sharing options...
tommac Posted November 13, 2008 Author Share Posted November 13, 2008 Thanks guys- just the ticket! Quote Link to comment Share on other sites More sharing options...
Robot_Roo Posted June 6, 2009 Share Posted June 6, 2009 Hi guys,new to this forum,Great site, just bought an old disco to play with. I am just replacing the cylinder head thanks to the advice given on this forum, I am up to the rockers, and just have one query if anyone could help, I have fitted new pushrods and i notice that the front 5 are all sitting at different heights, but the back 3 all seem to be about the same level, is this normal before I go any further or could it be a problem? I cant finish the putting the rockers and stuff in till next weekend but thouhgt i would ask this question am I worring unnessarily? Quote Link to comment Share on other sites More sharing options...
western Posted June 6, 2009 Share Posted June 6, 2009 could be some are not seated in the followers correctly. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 7, 2009 Share Posted June 7, 2009 Look down the pushrod hole and make sure the ball end of each rod is sited centrally in the pushrod slide - this thing. If the rod is off to one side of the slide, then the valve may not close and will either stay open while the engine runs (badly), or break the edge of the cup in the centre of the slide. Les. Quote Link to comment Share on other sites More sharing options...
Robot_Roo Posted June 7, 2009 Share Posted June 7, 2009 Look down the pushrod hole and make sure the ball end of each rod is sited centrally in the pushrod slide - this thing. If the rod is off to one side of the slide, then the valve may not close and will either stay open while the engine runs (badly), or break the edge of the cup in the centre of the slide. Les. great thanks guys will check it out Quote Link to comment Share on other sites More sharing options...
