blue band tube?
Bobtail-Jay
hi all i want to build a cage for my bobtail and was just woundering if blue band pipe is ok i will not be doing any competing in it ,it will just be for p+p days ?
does it bend easy what sort of bender will i need?
and whats good places to get it from?
and what sort of price am i looking to pay i see some one on here said it was £4.50 a metre last year some time?
cheers jay
I bought 20-metres of blue band (BS EN 10255) - also referred to as gas pipe.
Safe/recommended/approved for roll cages.
I also bought a Sealey 10-ton pipe bender.
What you buy to bend it with is the problem - some are real rubbish (mostly the formers), which kink, flatten to some extent, or otherwise damage the pipe.
Whatever you do - don't use scaffold poles!
Les.
without spending a lot of money on a decent bender you'll find it difficult.
the normal clarke jobbies aren't up to scratch.
i've got a full cage & tray made out of cds and it's the best money i've spent :) i got some 1 1/4" blue band for other jobs which i bent fine, but the 2" (well 48mm) stuff i battled with.
G
thats for spaceframes?
the specs for roll cage material is on page 155 and conts over on 156, it states cold drawn steel (CDS)! blue band is seamed and doesnt have a high enough yield strength!
if you only doing pay and play days then its fine, however if or when winch challenges go MSA it wouldnt pass scruiteneering!
He's right trust him (well, you won't trust me :lol:)
BB Is approved,
look under the tubes sizes options and wall thickness etc, it says something like BS1387
it does not say "Blue Band Red Band" as these are more names its known
as I think rather than as BS1387 which is the approved code for BB RB
I can't look it up in my MSA Blue Book as it has been loaned to a certain Forumeer :)
Nige
The MSA covers roll cage structures for all forms of motorsport. Blue Band and Red band IS suitable for cross country vehicles under the MSA regulations.
The AWDC is the largest national off road club and uses the MSA blue book as the basis for its technical regulations If you build your roll cage to the AWDC tech regs, it will be suitable. Here are the AWDCs roll cage requirements for 'safari' competitions (speed events) and compliance with these regs will give you a very strong and safe cage, suitable for trials, safaris and challenge events:
9.19 Roll over bars/cages
Aluminium alloy roll over bars and roll cages
are banned in all forms of motorsport where a
roll cage is required to be fitted. Full roll cages
as per drawing 2 below are mandatory in all
classes.
a. General Considerations
i. The basic purpose of the roll over bar is to
protect the driver/passenger if the vehicle turns
over or is involved in a serious accident. This
purpose should not be forgotten, and in consideration
of this, all roll bars and roll cages
should be built to the following RAC specifications,
as detailed in Paragraph 9.19.b (below)
or to an approved Cross Country Vehicle and
Four Wheel Drive design, which should in any
case incorporate many of the provisions
detailed therein.
ii. The roll over bar/cage must be designed to
withstand compression forces resulting from
the weight of the vehicle coming down on the
roll bar/cage structure, and to take fore and aft
loads resulting from the vehicle skidding along
the ground on its roll structure.
iii. All classes must have a full roll cage with
two rear facing braces and a cross brace situated
either within the main rear hoop or as close
as possible to it as in Drawing 1 below.
b. Fabrication
i. The main hoops and rear braces must connect
direct to the chassis by either welding or
bolting. One continuous length of tubing must
be used for the hoop member with smooth
continuous bends and no evidence of crimping
or wall failure.
ii. All welding must be of the highest quality
with full penetration. Wherever possible gas
shielded arc welding should be used.
iii. For space frame vehicles, it is important that
the roll bar structure is attached in such a way
as to spread the load over a wide area. The roll
bar should be designed as an extension of the
frame.
iv. For monocoque vehicles, consideration
should be given to using a 360 degree hoop
completely around the inside of the vehicle,
thus substituting for a frame.
v. Braces should be of the same size tubing as
used for the main structure, their fixing should
be located as near as possible to the top of the
roll bar, and in any case, at a minimum of three
quarters of the height of the roll bar.
vi. The mounting plates of the roll bar braces to
the chassis must be of steel plate of minimum
thickness 3mm, welded, riveted or bolted onto
the chassis. The total surface area of each plate
should be not less than 120sq cm of which at
least one third connects with a chassis vertical
member. The chassis outrigger to carry the roll
bar mounting must be a minimum of 75mm x
50mm x 3mm box section.
vii. The mounting of the main roll bar hoop(s)
must be secured with at least three high tensile
steel bolts and nuts (either hexagonal headed
or cap head bolts of minimum diameter 8
mm/0.315 in). The attachment plate to the roll
bar braces must be of the same thickness as
the wall of the tube. When the roll bar rests on
a box member of the latter, it must be locally
reinforced by a structure constituted of either
welded bolt heads or welded tubing ends.
viii. Removable connections used in roll bar
design should conform to the recommendations
within the MSA blue book.
ix. Bolts and nuts used should be of highest
quality steel (preferably aircraft standards) and
be of sufficient minimum diameter according to
the number used. Square head bolts and nuts
are prohibited.
c. Closed Vehicles - as a general rule, the safety
roll over bar structure must be made of two
hoops, one behind the front seats and the other
following the windscreen pillars (Refer to current
MSA yearbook for full details of all drawings).
The structure must be constructed in
such a way as not to obstruct access to the
front seats and not encroach upon the
driver/passenger space. It may encroach upon
the rear passenger space. The main hoops
must be placed as near as possible to the roof.
It is permissible to mount a longitudinal support
at door level providing it forms part of the
structure and is of similar tube dimensions. It
may be welded in or located with approved
couplings. It must not be higher than one third
of the door height above the sill and angled at
more than 5 degrees with the horizontal.
d. Open Vehicles - to the same specifications as
Closed Vehicles, except the main hoop must be
symmetrical about the longitudinal centre line
of the car and complying with current MSA
drawings.
e. Other Considerations
i. An effective roll over bar must be fitted of a
height not less than 50mm at its top edge
above the helmet of the normally seated driver.
It must be wider than the driver’s shoulders at
that height. It must be constructed of steel tubing
of minimum 44.30mm diameter with a minimum
wall thickness of 3.2mm. It should have
a hole of 6mm drilled in the underside for
checking the tube thickness. It should have the
top bar straight or curved, but not tubes meeting
in an inverted ‘V’. It must be effectively
braced to a structural member.
ii. Closed vehicles the main roll over bar hoop
must be placed as near to the roof as possible.
iii. Non-standard vehicles are advised to fit a
safety roll over bar to the following minimum
requirements: minimum height 710mm from
the rear of the uncompressed seat cushion, of
minimum flat width 380mm running into radius
corners and affording driver and passenger
equal protection. It must be mounted to a
structural member with front mountings not
less than the cockpit width and braced rearward.
f. Diagonal Struts - these should be fitted such
that the upper forward joint is on the driver’s
side of the vehicle to add further support in the
area of the driver’s head.
g. Materials - (All dimensions represent minimum
requirements.) Tube Specification: Cold
drawn seamless carbon steel, minimum yield
strength 350 N/sq.mm. An alternative material
is BS1387 medium weight blue band, dimensions
being 44.30 mm x 3.2mm for vehicles up
to 1000kg or 48.00mm x 3.2mm for vehicles
exceeding 1000kg. All diameters are outside
diameters. In all groups recognized manufacturers
may utilize a roll over bar of free conception
as regards material and tube thickness
providing it is able to withstand three simultaneously
applied loads:1.5 w lateral5.5 w fore
and aft 7.5 w vertical w = weight of vehicle plus
75 kg. Roll over bars of this type must be supported
by a duly signed and completed Safety
Roll Bar Certificate. The roll bar manufacturer
must be registered with the MSA Ltd. Titanium
is prohibited.
h. Roof – all vehicles must be fitted with a solid
roof panel. Specification for roof is a panel
which is sufficiently strong enough to protect
the occupants in the event of a rollover. The
panel must cover all occupants adequately. An
MSA scrutineer has the final decision as to
what is sufficient. When fitted to the roll cage,
the panel should not be riveted into the tubing,
but to a welded on flange.
You can find these regs on the AWDC web site.
Hope this helps,
Regards,
Diff
you can go on forever opening cans of worms with this topic!
what gets me is cds needs to have a minimum yeild strengh of 350, however bs1387, (which does not exist anymore as bs (british standards) has been superceeded by european standards) only has a yeild strength of 180-190.
strange!
If you want successfully bend "blue band" with a Clarke bender then insist on buying British Chorus steel, it resists kinking a bit more than our imported cheap stuff, but pays for itself in wastage and strength.
The boys who fit this stuff for a living (heating systems etc) who buy from Stockports "Booles Tools" will only use imported pipe for straights but when they are bending, they use the Chorus stuff (I know it's owned by Indians but they have apparently not lessenend the quality) and they insist that is the most cost effective way.
I hope that may help or explains things.
