in cab control for 8274
rob90
I want to wire my front 8274 winch for in cab controls using a carling switch.
on the solenoid pack and hand control there is 5 wires I have done the usual search and only come up with a 3 wire version.
after waving the multi meter around i found out the following
there are
red wire = earth
white wire = 12v+
green wire?? I think winch in
brown wire?? I think winch out
black wire??
I tried wiring without the unknown wire but no luck
any one shed some light on this for me.
thanks
the 8274 standard remote switches the earth aswell as the live,
i had to put a permanent earth to the standard solenoids(simple wire from the earth on the bottom of the wire) then you just wire it like a normal solenoid to the carling switch.
Ian
Ian
So if im reading this right, the unidentified wire just switches to earth? so if attach to the end of this wire and route to the earth on the motor?
or am I being dumb?
