Orgasmic Farmer Posted December 7, 2008 Share Posted December 7, 2008 Does anyone know if the strip that holds the door glass and attaches to the winding mechanism is available as a seperate part. The bit I need is the sprung steel channel with a rubber strip inside it that is a tight fit on the lower edge of the door glass. Part number would be great thanks Mark Quote Link to comment Share on other sites More sharing options...
cipx2 Posted December 7, 2008 Share Posted December 7, 2008 Yes, the rubber strips and the channels are available separately. For part #s you need to tell what year is your Discovery and which door, front or rear. Quote Link to comment Share on other sites More sharing options...
bobtail4x4 Posted December 7, 2008 Share Posted December 7, 2008 They are about £11, tip dont bother stipping the door down, just clean the bottom of the glass, lower the window half way. then run a bead of body sealant in the new channel. put the chanel on the glass and use the motor to lift it in place, wait a few hours and its fixed. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted December 7, 2008 Author Share Posted December 7, 2008 Thanks for the replies. Its a 1996 300 tdi drivers door (2 door commercial). As a temporty fix I have done what you suggest with the old channel. Cut the rusty bits off, put some silicone in the rubber and stuck it back on!! Its working so far! Quote Link to comment Share on other sites More sharing options...
cipx2 Posted December 7, 2008 Share Posted December 7, 2008 ALR8990 - Glazing Rubber ALR8022 - Channel - front door no matter which front door. Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted December 7, 2008 Share Posted December 7, 2008 i have 2 manual mechanisms up for grabs if you want Quote Link to comment Share on other sites More sharing options...
