titan Posted February 23, 2009 Share Posted February 23, 2009 im wonting to fit a roof rack or expodition rack to my disco but it didnt come with the roof bars i have seen some on flebay but was wondering how easy these are going to be to fit and where to drill the holes as my disco dosnt even have the holes drilled ?? Quote Link to comment Share on other sites More sharing options...
cipx2 Posted February 23, 2009 Share Posted February 23, 2009 Basically, you'll have to do the reverse of what you can see here: http://www.discoweb.org/roofrails/index.htm After removing the headlining you'll see the corresponding threaded holes, drive a pointed tool through them to mark the center of the holes, drill the 34 mm diameter holes from the top of the roof, paint/protect the hole edges from rust, use some silicone and screw the bars down, put the headlining and the rest of the bits back up and you're done. Quote Link to comment Share on other sites More sharing options...
titan Posted February 23, 2009 Author Share Posted February 23, 2009 Basically, you'll have to do the reverse of what you can see here: http://www.discoweb.org/roofrails/index.htmAfter removing the headlining you'll see the corresponding threaded holes, drive a pointed tool through them to mark the center of the holes, drill the 34 mm diameter holes from the top of the roof, paint/protect the hole edges from rust, use some silicone and screw the bars down, put the headlining and the rest of the bits back up and you're done. cheers in answering that for me you helped me find a better route for me to take thanks Quote Link to comment Share on other sites More sharing options...
