Hybrid_From_Hell Posted April 14, 2009 Share Posted April 14, 2009 Found a thread you think should be in here ? Just hit "report" from within the thread and 'recommend' it - we'll do the rest Below is a helpful Index to some of the more popular and useful posts in the Tools & Fab Forum This is complementary to the Technical Archive section which you should also visit and study, there may be some duplication, but better to have something twice than to miss it - "Enjoy" INDEX Tools n Stuff Tools Sizes for specific Jobs on LRs Make your Own V8 Rover Oil pump primer Make your own Series drop arm puller Make your own V8 Crank pulley Puller Make your own Series shock absorber pin fixer Trick for tapping out hard to access holes How to sharpened drill bits Gapping plugs - simple cheap tool All sort of Home Made Equipment - Tools - Projects Make your own Dimple Dies More Dimple Tech Do your tracking on your own DIY Brackets Making Leaf brackets on a Coil Sprung axle Modified Cross members - Outriggers etc Making a Rear Winch Bumper - HD Rear Crossmember Selection of options Usefull Downloads Zeus HandBook - Dowload your copy here All things"Roll Cage" Ooooo Ahhh You want to make a roll cage Tools Tips Welding Tube work help Make your own roll cage tube notcher This makes tube notching shapes for joining all angles of tubes together Home Made Tube notcher - sander Welding Buyers Guide to Buying a MIG Welder and Member Models used with Pros and Cons Help with learning to weld upside down Snorkels Snorkel - DIY making of (1)V8 Freaks - Les Henson Snorkel - DIY (2) HFHs - There are others on this do a search Workshop Projects Making your own Workshop Heater - Wood Burner stylee More DIY Heater build project Make your own workshop storage - draw system More 'Make your own Storage' - some workshop some 4x4 based Link to comment Share on other sites More sharing options...
