Front cover for a Short R380 suffix L
Finally got round to building myself a short R380 gearbox for my 200tdi tonight.
All went well and everything works (only tested by hand though) but i've had to fit the TD5 face plate at the moment as the LT77 one's bearing size is different. I need the style of the old TD / Tdi era with the shaft for the clutch bearing to slide up i think, unless anyone else knows of another option
LT77 front assembly
FRC4856 upto & including suffix E box
FTC311 from sufix F
FTC1438 for prefix 50A suffix G & H & all prefix 56A
FTC2922 for prefix 61A
Thanks western but not of them will fit as the pinion bearing is larger on the R380 so won't fit into the plate.
I think the one i'm after will be listed as front cover for R380 4cyl excluding tdi.
OK, the R380 version for Tdi gearbox is FTC3696
beamends site says it's supersed by FTC5371
Microcat shows suepersed by TVQ100130
All of them are Tdi versions and won't fit the box i'm building unfortunately.
Does HRC2677 show up on microcat as an available part ?
Any HRC number is just a casting number not a LR part number.
that part is a LT77 part, R380 was never fitted to TD & 200Tdi engines. as the R380 didn't exist until the 300Tdi came out.
these are the relevant parts diagrams for LT77 & R380 boxes associated with TD or Tdi engines.
