Very Quick MOT question
bishbosh
I think a split CV gaiter is a fail under section E1a, see http://www.motuk.co.uk/manual_250.htm
Whereas a TRE gaiter (dust cover) is only an advisory (or whatever it's called), according to http://www.motuk.co.uk/manual_220.htm (see Steering Joint dust cover).
Don't shoot the messenger as he's not that familiar with the UK MOT system (but it's pretty much the same in EU). :P
CV and steering rack gaiters split are a reason for failure , Split TRE boot is not a reason for failure , Its an advisory ,
Have you submitted it for test yet Bish , Just for piece of mind stick a new joint on ,for less than 25 quid do the lot . A split boot aint going to get better and repairing them is more hassle than its worth .
Is a split TRE gaiter an MOT fail? There is no play in the TRE, but the gaiter has been pinched and has split. It is on the hub end of the drag ink if that makes any difference.
Thanks,
Pass and advise, it doesn't even come under the steering section, it a non-component related advisery
Well it was MOT'd today. TRE gaiter not a problem, but the absence of one of the two poxy little bolts used to locate the A frame ball joint was!
The annoying thing is that it has been like that for 3 years and MOT'd at the same place each time. The ball joint went in slightly crooked so I could only get one of the bolts in.mad.gifmad.gif
Ho hum. New ball joint tomorrow then.
my mot tester on Thursday failed on a brake pipe not being secure
he past it last year but to be fair he did let me fix it so it passed in the end
