leigh Posted February 2, 2010 Share Posted February 2, 2010 I'm planning on changing the oil in my gearbox and transfer box. (1991 2.5 petrol ninety - so LT77 and LT230 I assume...) I have looked at various guides but none mention what size the copper washer is on the drain plug(s). I rather get one before taking the plug out and finding its knackered! I guess I'll need one for each of the drain plugs on the gearbox and one for the transfer box? Also, on the taper filler plugs, is a couple of wraps of ptfe tape a good idea? Any help appreciated Leigh Quote Link to comment Share on other sites More sharing options...
western Posted February 2, 2010 Share Posted February 2, 2010 I'd go for the proper items from these links for example, then you can be sure it wll fit correctly LT77 gearbox drain washer FTC4112 here LT77 gearbox extension case drain washer FRC4810 here LT230 transferbox drain washer FRC4808 here hth Quote Link to comment Share on other sites More sharing options...
leigh Posted February 2, 2010 Author Share Posted February 2, 2010 Thats brilliant, thanks. Just need to order some motivation and actually get on with it on saturday... Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 2, 2010 Share Posted February 2, 2010 As long as the copper washers are full copper washers and not the crushable type I'd just anneal them. I think you'll find the sump washer is crushable. For the sump i'd be throwing the normal drain plug away and fitting onme of those from Difflock. Much easier to do the oil change. Quote Link to comment Share on other sites More sharing options...
