Gilslandy Posted March 12, 2010 Share Posted March 12, 2010 Hi guysss.. I bought the shock absorbers mountings to fit pin-pin plus 5.5 shocks, but i have a small problem. The mounting on the driver side can't be fitted cos there is the diesel filter on the way! Has anyone encountered this problem pls?? Thanks alot Gilbert Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted March 12, 2010 Share Posted March 12, 2010 Common problem i believe when fitting the new mounts and shocks, Only solution i think is to move it slightly. Im Not 100% but im sure someone will confirm. Dave. Quote Link to comment Share on other sites More sharing options...
Gilslandy Posted March 12, 2010 Author Share Posted March 12, 2010 ok thanks! For who already experienced this...did you work a new bracket for the filter? did you use same pipes? any pics please? Thanks mates! gil Quote Link to comment Share on other sites More sharing options...
101sean Posted March 12, 2010 Share Posted March 12, 2010 I've got the same problem. Gwyn Lewis supplied a bracket to resite the filter but it didn't work as there's not enough give in the pipes (fine on a Puma though). The filter is temporarily bolted direct to the chassis without the mounting plate, there's holes that line up, still a bit of a tight fit and they will chafe eventually. I'm waiting for my brother in law to weld me up a Z shaped bracket to move the filter out and up an inch, about the limit of give in the pipes. I can take a photo of the filter as it is now. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted March 12, 2010 Share Posted March 12, 2010 I did this and moved the filter set up across drilling a new hole in the standard back using the standard hoses - I took a few photos, I'll look for them and post them up. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted March 12, 2010 Share Posted March 12, 2010 I remember asking Gwyn about it when I came to fit mine - he said he wasn't sure how it was done, but said no one had come back to him about it so presumed it can't be too difficult to sort out. This is how I did it - remove the guard leaving the filter and pipes connected: Mark out the hole spacings on a bit of card, as you look at the chassis there are two top bolts that hold the filter and the bracket, and two bottom ones that just hold the bracket: I decided that 4 bolts to mount it was overkill and so iirc elected to just use two ( a top and a bottom) and rotate the mount around the top left hole and fit it onto the top right hole on the chassis ..... if that makes sense. So I rotated the bracket around the top right hole on my template: and marked the bottom right hole by pushing through the template to mark the bracket: I then drilled the hole: But as I didn't have a large enough drill bit - I opened it up a bit with an old engine porting tool: I then realised I'd done it on the wrong place and so repeated the procedure in the right place...... Then just bolted it up, the pipe work is stiff and there isn't much leeway, but if you do it like this it'll move enough to allow the new mounts to fit without having to remove or extend the pipework : It immediately felt firm enough to satisfy me that 4 bolts was over kill. If it hadn't I'd have drilled a new hole in the chassis and used a nutsert. I've done lots of miles both on and off road on it though and its not moved at all. Quote Link to comment Share on other sites More sharing options...
Gilslandy Posted March 13, 2010 Author Share Posted March 13, 2010 Thanks so much!!! very detailed explanation! it will help me for sure! Gil Quote Link to comment Share on other sites More sharing options...
