Brake system G-Valve
Is this the one on the inside chassis rail? Not 100% sure, but I seem to remember that it's something like a bias valve that limits the braking force applied to the rear circuit, to prevent the rear locking up under heavy braking.
Correct :i-m_so_happy:
I send you my address........
At the (small) risk of spoiling a (good) joke, the G valve has a ball bearing in it. The harder you decelerate the harder the ball is pressed forwards to try and keep the pressure in the rear circuit below the point where the back wheels will lock up. The valve is fitted at a specific angle (front end up) to stop it activating too soon.
