bm52 Posted September 16, 2010 Share Posted September 16, 2010 Hi, i was wondering if anyone on here has experience of sorting out the suspension on a Puma 90. Mine is very very hard and jiggles and shakes on most roads. I have identified the spring colours so I know I have the springs for the 2550kg setup. Mine is a 4 seat XS 90 with no extra weight and I will mainly use it on roads and green lanes/tracks. i will only occaisionally have passengers in it. any idea how i can make the ride smoother, any ideas on a better spring and / or damper set-up? 90 4 seat station wagon (2400 Kg) Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side RKB500290 Red/green/green Rear - Passenger side RKB500280 Red/green/red 90 4 seat station wagon (2550 Kg) Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side RKB500270 White/green/pink Rear - Passenger side RKB500310 White/green/purple Quote Link to comment Share on other sites More sharing options...
fekete Posted September 17, 2010 Share Posted September 17, 2010 Hi i think your springs are fine you need to put some good shocks on i have the bilstains and find they make the ride much smoother Quote Link to comment Share on other sites More sharing options...
Aragorn Posted September 17, 2010 Share Posted September 17, 2010 You'd probably benefit from running the softer rear springs. even in non-HD trim, 90's have pretty stiff rear springs, so if its running unloaded most of the time the 2550kg setup will probably be overly stiff Quote Link to comment Share on other sites More sharing options...
