Les Brock Posted July 18, 2011 Share Posted July 18, 2011 Ralph/anyone I have the following which is a bit mix and match, so going by chassis number/year is no use what so ever Front Calipers (110 I Think) STC 1962 (SEB500450) 46mm piston STC 1963 (SEB500440) 46 mm Piston Disks FRC7329 (298mm diameter 70mm depth) Rear Calipers 110( Again 110 I think) STC 1968 46mm Piston STC 1969 46mm Piston Disks SDB000330 (298 diameter 61mm Depth) Could anyone please confim which pads I should have and the pad retaining kit/pins to go with them ? I'm sure looking at them they are proper pins not split pins as the holes look to large but not 100% sure Loooking to use Green Stuff pads but need to confirm the original part no first Thank you Regards Les Quote Link to comment Share on other sites More sharing options...
western Posted July 18, 2011 Share Posted July 18, 2011 Front ----- solid pins & anti rattle coil spring type STC8575 or RTC5001 possible same contents as above but shorter pins for non vented disc Rear ---- SFP000280 or STC8574 depending on which rear pads you have. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted July 20, 2011 Author Share Posted July 20, 2011 Cheers Ralph Quote Link to comment Share on other sites More sharing options...
