Matthew L Posted October 9, 2012 Share Posted October 9, 2012 I am thinking of adding driving lights to my 2005 TD5, but the proper center console switches are ridiculously expensive. Is there any reason I couldn't use a rear fog lamp switch to trip the relay to the driving lights and put it in the blank spot opposite its twin and just mark them appropriately? Cheers, Matthew Quote Link to comment Share on other sites More sharing options...
PaulMc Posted October 9, 2012 Share Posted October 9, 2012 I am thinking of adding driving lights to my 2005 TD5, but the proper center console switches are ridiculously expensive. Is there any reason I couldn't use a rear fog lamp switch to trip the relay to the driving lights and put it in the blank spot opposite its twin and just mark them appropriately? Cheers, Matthew The rear foglamp switch won't work. It's a momentary (non-latching) switch, that switches to earth. The rear fog lamps are switched by an ECU that detects this momentary path to earth and then switches on the rear fog lamps (only if the headlamps are also 'on'). The switch that you're looking for is the Defender Puma Heated Seat Switch - YUF500150LNF This is a latching live-switching switch, which costs around a fiver http://www.rimmerbro...-i-YUF500150LNF £4.17 ex VAT (£5.00 inc VAT) It uses the Black 5-way switch connector, which I sell on eBay - http://www.ebay.co.u...nnectors/m.html It should be wired, as follows - Pin 1 - Live in from fused supply Pin 2 - Live from dash illumination Pin 3 - Not used (but is internally connected to Pin 5 - Earth) Pin 4 - Switched live out to accessory Pin 5 - Earth You can swap the 'Heated Seat' switch cap for one from another switch, including the rear fog lamps switch. . Quote Link to comment Share on other sites More sharing options...
Matthew L Posted October 10, 2012 Author Share Posted October 10, 2012 Thanks for this. I am away from my TD5 right now, so a couple of questions... 1. Will this switch fit and look right in the top left spot in place of the blank? 2. Since I don't have any extra switch caps, is there a neat way to remove the icon and relabel the switch or a source for the right cap or a blank one? Thanks! Quote Link to comment Share on other sites More sharing options...
PaulMc Posted October 10, 2012 Share Posted October 10, 2012 Thanks for this. I am away from my TD5 right now, so a couple of questions... 1. Will this switch fit and look right in the top left spot in place of the blank? 2. Since I don't have any extra switch caps, is there a neat way to remove the icon and relabel the switch or a source for the right cap or a blank one? Thanks! 1. Yes it will - but, you'll have to trim-off the moulded keyway at the back of the switch body (top right in the picture above). 2. You can use the cap off of the switch blank, but you will need to drill a 2.5mm hole for the tell-tale warning light's 'lense' Have a look at this - http://www.lro.com/f...=385823#p385823 The switch caps are made from translucent white plastic, which has been sprayed black or Ash Grey, with the symbol masked-out, so that when back-lit, the symbol illuminates. If you're good with a Dremel, you can engrave your own symbol in the blank, like the home-made cruise control switch, here - http://www.lro.com/f...hp?f=18&t=58151 Or you could use a stick-on symbol, like these from VWP, or MUDSTUFF - The MUDSTUFF symbols are clear on black, so if you polished away a small area of the paint finish on the blank switch cap (under where the symbol is going to be stuck), the symbol will illuminate with the dash lights. Although they haven't pictured the sheet, MUDSTUFF also do a White on Clear sheet, which could be used on a blank switch cap , without any polishing away of it's paint finish. Of course, this wouldn't illuminate with the dash lights. . Quote Link to comment Share on other sites More sharing options...
Timpo Posted March 7, 2016 Share Posted March 7, 2016 This thread is of great help..... I'll just put a post on it so I can find it later. :-D Timpo. Quote Link to comment Share on other sites More sharing options...
western Posted March 7, 2016 Share Posted March 7, 2016 Added to our 'Popular modifications' list in tech archive under electrical section. http://forums.lr4x4.com/index.php?showtopic=92553 Quote Link to comment Share on other sites More sharing options...
