300tdi oil path???
Like Ralph says. Most likely yes but lower.
I'll bet you ten bob the oil pump has spun on the crank.
The oil pump will provide a pressure of 3>4 lbs still lubticating the engine for a long long time before the oil light goes out.
We did well over 50 miles when the gauge dropped but the oil light stayed on until well after the gauge shewed nearly zero.
Isn't there ??? I didn't have any instructions when I had to do mine. I just made sure that there was oil in the pump.
Or was this one fitted dry ?
It the filter hasn't go any oil
THEN
Oil strainer, assuming oil in sump, is blocked
Oil pick up pipe blocked.
Air leaking at pick up pipe at "O" ring where the pick up pipe enters the block.
OIl way from oil pump to filter blocked.
From those.
Oil pimp "fingers" broken or not fitted to crank correctly
Nose of crankshaft "rounded" not allowing the oil pump to turn.
Any more ? ?
