Water level Monitor plug and play
Maverik
  • 3 weeks later...
  • 4 weeks later...
Based on the good comments in this thread I ordered one, and it arrived today. But, it had no instructions, and not even the diagram that appears in post #6. So, what goes where? In the post #6 photo there are two connections marked "supply" and two marked "Probe", so what's what? Please, can anybody who has successfully installed one please tell me how to connect it up?
Many thanks, in advance, for any help.
Mike
For our 300 TDI Discovery I used an Interface Solutions IS M12T transistoriesed relay, bought from CPC in Preston for about £14. The Range Rover water level sensor seems to change from 1meg ohm to about 680 ohms, and the M12T can be wired to detect this change. A volt free contact in the unit can then be used to switch what ever warning you want.
I have not had to use it in anger, but it seems to work well when I lift the sensor out of the water to test it.
  • 1 month later...
