kevcon Posted February 12, 2014 Share Posted February 12, 2014 Friend at work has a 2003 Freelander Kalahari TD4. Has had it 8 month and can really afford to run it. Has 112000 on the clock 2 owner part service history Has had 4 new tyres Brakes all round Rear diff Rear bushes Abs sensors Bearing/CV joint on front And drive shaft to same side. Rear windows don't work. Cable needed. Also has in his description bigger alloy wheels like the RRSport but smaller. Wants £2000 for it The questions are Should I buy it and keep it? Is it worth buying and selling on? Or should I go for a facelift model as on a whole I do like the look of them better. Have had a bit of experience with Land Rovers as have a Disco2 4.7 v8 on LPG and in the past had a RR Overfinch Supercharged. Kev Quote Link to comment Share on other sites More sharing options...
EggNChips Posted February 13, 2014 Share Posted February 13, 2014 I wouldn't buy it to sell on, but would buy it to keep. The Kalihari is quite well spec'd and the TD4 is excellent. Regulator repair kits are around £20 each. If you've got the money and prefer the Facelift tho makes sense to buy what you like. Quote Link to comment Share on other sites More sharing options...
