ricci Posted October 11, 2014 Share Posted October 11, 2014 Hi, Im new to the forum so sorry if this sound like a dumb question, but I want to be sure before connecting. I currently have a TD5 and want to replace the cigarette lighter () with one of these: However, the USB socket has only + and - terminals, whereas the old cigarette lighter has a black wire, purple/green wire, and red/yellow wire connected to it: I'm guessing that the wires are as follows: black - earth purple/green - 12V red/yellow - to connect the bulb Could someone confirm this please? I cant test them as its a bit difficult to get my hands on a multi-tester at the moment. Thanks Quote Link to comment Share on other sites More sharing options...
eds Posted October 11, 2014 Share Posted October 11, 2014 Agree :-) Quote Link to comment Share on other sites More sharing options...
AndrewHorsfield Posted October 12, 2014 Share Posted October 12, 2014 I always check with a multimeter or test light. I think the old fitting will only light up when the side lights are on. Quote Link to comment Share on other sites More sharing options...
western Posted October 12, 2014 Share Posted October 12, 2014 Hi, Im new to the forum so sorry if this sound like a dumb question, but I want to be sure before connecting. I currently have a TD5 and want to replace the cigarette lighter ($(KGrHqV,!ncE63T0+q3jBO+C0OquZg~~60_57.JPG) with one of these: $_12.JPG However, the USB socket has only + and - terminals, whereas the old cigarette lighter has a black wire, purple/green wire, and red/yellow wire connected to it: IMG_20141011_140514.jpg I'm guessing that the wires are as follows: black - earth purple/green - 12V red/yellow - to connect the bulb Could someone confirm this please? I cant test them as its a bit difficult to get my hands on a multi-tester at the moment. Thanks agreed, just checked with my 2002 wiring diagrams. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted October 12, 2014 Share Posted October 12, 2014 I just fitted one the same and thats right. Quote Link to comment Share on other sites More sharing options...
reb78 Posted October 12, 2014 Share Posted October 12, 2014 I just fitted one the same and thats right. Have you got a link to it? First one I've seen with a 2.1 amp output. Quote Link to comment Share on other sites More sharing options...
AMB Posted October 12, 2014 Share Posted October 12, 2014 Have you got a link to it? First one I've seen with a 2.1 amp output. Mudstuff do one. or buy an adapter from Ebay at £2-49 Quote Link to comment Share on other sites More sharing options...
eds Posted October 12, 2014 Share Posted October 12, 2014 Try this one.............. http://www.ebay.co.uk/itm/Dual-USB-Car-Cigarette-Lighter-Socket-Splitter-12V-Charger-Power-Adapter-Outlet-/231307335084?pt=LH_DefaultDomain_3&hash=item35dafdd5ac I fitted this usb device but the thing has an led on it which means it needs a switch or an ignition feed which might not be appropriate if you need power all the time. I just fitted a switch. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted October 12, 2014 Share Posted October 12, 2014 I bought mine from Amazon, specifically for the 2.1 amp output .... Blue Sea - Dual Usb Charger Socket - 2 Usb Ports W/Watertight Cap https://www.amazon.co.uk/dp/B0082CXEI8/ref=cm_sw_r_awd_dpOoub0A8GAXM Couple of years ago and it's been great. This last fitting was swapping it into my new 90. Quote Link to comment Share on other sites More sharing options...
ricci Posted October 12, 2014 Author Share Posted October 12, 2014 Thanks guys for the confirmation...will give it a go tomorrow cause i still need to buy the connectors Quote Link to comment Share on other sites More sharing options...
Anderzander Posted October 12, 2014 Share Posted October 12, 2014 You can use the existing wiring and its connectors - well I could on the two td5's I've fitted it to. Quote Link to comment Share on other sites More sharing options...
Aussi Outback Boss Posted January 10, 2015 Share Posted January 10, 2015 I am also a new Newbee, have a 300TDI and is restoring a 1964 11A FFR (military) I am changing cigarette lighter to USB: ​The problem I have is there are 4 wires coming out to the cigarette lighter Red/Yellow- LIGHT Green Black White ​if i connect green and black the USB is not working, i am not getting 12V, I am getting less (do not know how much). Do any one have an answer please Quote Link to comment Share on other sites More sharing options...
eds Posted January 10, 2015 Share Posted January 10, 2015 USB is 5 volts? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 10, 2015 Share Posted January 10, 2015 Are you sure that the green isn't from the rear wash wipe ? I thought the lighter sockets were all 3 wires ... Quote Link to comment Share on other sites More sharing options...
discomikey Posted January 10, 2015 Share Posted January 10, 2015 USB is 5 volts? i would hazard a guess that the unit had a built in voltage regulator Quote Link to comment Share on other sites More sharing options...
Raggylad Posted January 13, 2015 Share Posted January 13, 2015 I did this mod (on a 1983 110) a few weeks ago. I worked out the + & earth leads and also the light bulb connections - still dead. In-line fuze (35A) further back in the loom had blown - duh ! Brilliant for charging the phone, running satnav, etc. Blue LED constantly on in the dash looks a bit weird in a 31 year old vehicle. Quote Link to comment Share on other sites More sharing options...
