bushwhacker Posted April 17, 2015 Share Posted April 17, 2015 Hi. Bit of an odd one. Alt belt snapped coming home form off roading, no problem order a new one for a 2.5nad ETC7939. Which the 200tdi and a few others use also. My mate had a spare so I thought handy but when fitted it it's about 2 inches to tight. I can't find any other belt listed so I suppose one of the pullies has been changed at some time. Or does anyone no any different. Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted April 17, 2015 Share Posted April 17, 2015 You got the route correct? Quote Link to comment Share on other sites More sharing options...
western Posted April 17, 2015 Share Posted April 17, 2015 Rear groove of crank pulley, alternator, water pump, is the alternator adjuster undone ? Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted April 17, 2015 Author Share Posted April 17, 2015 Thanks, yea route correct, and adjuster undone alternator up against the block. I got a new belt also and it is still way to small?????????????? I will have another look, and also get my buddy to run his eye over it. Quote Link to comment Share on other sites More sharing options...
western Posted April 18, 2015 Share Posted April 18, 2015 Dayco part 11A1025C is the LR equal, 1025 is the length in mm, always a pig to fit, maybe one 10mm longer would be better. Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted April 18, 2015 Author Share Posted April 18, 2015 Yea that''s exactly what was happening 1025 to tight 1030 still tight and either would have been a beast to fit. Ended up sticking a 1050 on from a Series something thanks to the local LR guy and it tensioned up perfect. I am in the process of going 300tdi and wouldn't you know the 2.5na plays up in it's last few days. Land Rovers. Thank guys. Quote Link to comment Share on other sites More sharing options...
western Posted April 18, 2015 Share Posted April 18, 2015 do you have the full part number for that 1050 belt please, might be worth swapping mine for a easier fit belt. Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted April 18, 2015 Author Share Posted April 18, 2015 Yes Part no 563132D by Dayco. Belt dim 10A1050C Quote Link to comment Share on other sites More sharing options...
western Posted April 18, 2015 Share Posted April 18, 2015 Thanks very much, I see it's 1mm narrower to, the first 2 digits are the belt width in mm. Quote Link to comment Share on other sites More sharing options...
Lewis Posted April 19, 2015 Share Posted April 19, 2015 I'm using a 13x1025 on my disco 200tdi, which is a nice fit Quote Link to comment Share on other sites More sharing options...
western Posted April 19, 2015 Share Posted April 19, 2015 had a look on Dayco's site late yesterday, they have a 11A1055C Belt in the Vee type, so it's 11mm wide & 1055 mm length Metric Part 11A1055 http://www.daycoproducts.com/part?category_id%3D1084%26year%3D1948%26make%3D%26modeltype%3D%26model%3D%26description%3D%26part_number%3D15415 Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted April 19, 2015 Author Share Posted April 19, 2015 I've had a look at the sleeve my new belt was in Dayco made in USA 2013. Got at the local LR center it has an Allmakes sticker on it with the date 22nd Nov 2013 so it has sat about for a while maybe they stopped making that one ? My snapped belt was Bosch AVX 10 X 1025 probably the one that was fitted on the production line. Quote Link to comment Share on other sites More sharing options...
western Posted April 19, 2015 Share Posted April 19, 2015 I get Dayco belts from my local LR parts guy & Gates variant from a local motor factors, not had any problem with either make. Quote Link to comment Share on other sites More sharing options...
western Posted May 3, 2015 Share Posted May 3, 2015 My snapped belt was Bosch AVX 10 X 1025 probably the one that was fitted on the production line. That's the same part number as the Gates alt,water pump belt Quote Link to comment Share on other sites More sharing options...
