RRC fueltank in 110" ?
Some models of RRC use the same metal tank as the 110.
I believe when the RRC went to plastic tank coincided with the arrival of the high-level fuel filler. I don't know for sure, but I would expect this may mean the filler neck is positioned differently on the tank.
The plastic tank also uses a different fuel pump/level sender assembly.
I daresay with the right motivation, it could be made to fit ;)
Yep that is correct, I'm not sure the tank inlet position is different, as there is a large rubber elbow joining the tank inlet, just above the chassis rail...?
IIRC they are slightly deeper than the metal RRC ones.
