Chambo110 Posted January 9, 2017 Share Posted January 9, 2017 Hi can anyone tell me what size the bolt is that goes in the hole under the hi low lever in this pic Or better still the part number for it thanks Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted January 9, 2017 Share Posted January 9, 2017 It should be a stud in there FRC5595 or a short bolt...if you fit a long bolt it can lock the intermediate gears. 1 Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted January 9, 2017 Author Share Posted January 9, 2017 Cracking , cheers mate. I've read about one of the bolts being to long could cause problems. I'm sure that's the bolt I removed that was bent over at the end and a bit mangled when I took the tbox out . !!! Does this also explain my diff lock and hi low not working since I've had it ??? Some clown put a long bolt in I guess!! ?? cheers again Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted January 9, 2017 Share Posted January 9, 2017 No, if there is a long bolt fitted in that thread it locks the box completely. The diff lock and hi-lo issues are something else 1 Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted January 10, 2017 Author Share Posted January 10, 2017 Oh ? Ok what the hell happened to this then ? this is the bolt I removed from that hole Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 10, 2017 Share Posted January 10, 2017 Looks like someone hung the box off it during assembly/disassembly, bending and mashing it up. No thread damage to the box? Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted January 10, 2017 Author Share Posted January 10, 2017 (edited) Takes some beating to get a bolt like this not looked at thread damage in old box as it's now in shed feeling sorry for itself ... assuming it's gotta be buggered. Surprised it actually came out with out breaking bolt I may , if bored, look into re furbing myself or sell on with a buggered hi low and diff lock for someone else to play with Edited January 10, 2017 by Chambo110 Quote Link to comment Share on other sites More sharing options...
Leclance Posted January 15, 2017 Share Posted January 15, 2017 I'm sure ive seen a video on you tube where the high low selector components get corroded with age and just need dissembling and cleaning up , from what i remember this was a fairly easy job . Of course watching you tube doesn't make me an expert so i could be wrong. 1 Quote Link to comment Share on other sites More sharing options...
