Salisbury Axle kit
DC_
I'll have a read up on that Les ta,
reb78, I'm easily confused or it's the fact my dog was up half the night and my brain has shut down now ? How to test breather then?
take the axle end off breather off, clean the hole in end fitting & blow it through with air line [if you have a compessor] or a foot pump from the axle end, you should feel any air coming out of the other end,  it's normal for ep90 to come out when the driving member is removed, put a blob of oil or grease in the rubber end cap before refitting it, it will keep the splines lubricated at the outer end & therefore last much longer.
  • Like 1
  • 3 weeks later...
