Cyclone breather 'O' ring dimensions - 300TDI
This question has probably been asked a hundred times, but does anyone know the correct dimensions of the rubber 'O' ring used on the cyclone breather ?
Thought I would go for the cheaper option of buying in bulk off eBay, plenty of sets available at good prices. Then I looked up the dimensions through google and ended up scratching my head, there are different sizes offered depending which aftermarket supplier you go for ?  with the same part number LO100000.
There is: 0.2 X 2.2 X 2.2   and  0.5 X 1.5 X 1.0   ? assume smallest value is the thickness ? but the other values don't make sense unless it's just me going simple in my old age.
I know easy solution is to take off the original and measure it, but leaking quite bad as it is at the moment.
I think might be a good idea to seal the O ring in with silicon when I replace it.
Ah you read my mind Mo, that was my original plan to buy a cheap set of multi size rings and find one that was a good fit.
My only concern was that I ended up forking out £5 for a kit with 255 variations and none where suitable ?
The kit I have in mind has both 15 and 20 mm diameter rings so will select the one with the thickest wall and use a touch of silicone for good measure.
Thanks for the info guys much appreciated.
