Eightpot Posted February 2, 2017 Share Posted February 2, 2017 Just when you think you're making good time.. Bit of a head scratcher here - fitting a new 300tdi front crankshaft inner seal (not dust cover seal) Parts catalogue has this as FRC4575 - can't find an alternative part number anywhere. This part is 4mm wider diameter than the seal that came out though. Checked against a spare engine and this also has a smaller seal. Checked two other FRC4575 in case they put the wrong seal in the order, none will fit - wasnt aware there were two seal sizes?? Quote Link to comment Share on other sites More sharing options...
western Posted February 2, 2017 Share Posted February 2, 2017 Should be ERR4575 not FRC see item 8 page 271 of http://www.retroanaconda.com/landrover/parts_books/90/4_engine_300_V8_p262-367.pdf which parts info gave you FRC4575 ? also we have a dedicated part number forum, to avoid culttering up the vehicle forums Quote Link to comment Share on other sites More sharing options...
Eightpot Posted February 2, 2017 Author Share Posted February 2, 2017 Sorry, meant ERR4575. Well this has got me stumped - the hole for the seal and the seal I fished out are far smaller than the 4575 seal I got with the timing kit or the two others (cortico and genuine) I had on the shelf. internal diameter for crank the same but there's no way an ERR4575 will fit in the hole. Quote Link to comment Share on other sites More sharing options...
western Posted February 3, 2017 Share Posted February 3, 2017 This ERR4575 is approx 75mm outside diameter & should correct as listed for all 300Tdi engines http://www.brit-car.co.uk/product.php/84975/0/crankshaft_oil_seal_300tdi_front___discovery_1___defender___range_rover_classic 200Tdi oil seal is a different part number & slightly smaller outside diameter, maybe you have a Discovery 200tdi engine & not a 300tdi. that would be the only explanation I can think of. http://www.brit-car.co.uk/product.php/447665/0/timing_cover_oil_seal_2_25_2_5_v8_series_111___defender___discovery_1___2___range_rover_classic___p3 Quote Link to comment Share on other sites More sharing options...
Eightpot Posted February 3, 2017 Author Share Posted February 3, 2017 Ok sorted it , thanks for looking. The wrong seal had been put in with the timing belt kit, and coincidentally the very same seal type had found its way into the wrong box in my store x 2!.. could be a signal from the universe telling me to put my numbers on this weekend. Correct seal now fitted 1 Quote Link to comment Share on other sites More sharing options...
western Posted February 3, 2017 Share Posted February 3, 2017 oh dear, glad you found out which seal is correct Quote Link to comment Share on other sites More sharing options...
retropower Posted February 5, 2017 Share Posted February 5, 2017 Sometimes when this happens you start to think someone has it in for you! I had two separate consecutive sets of faulty hydraulic cam followers from two different suppliers a couple of weeks back! Quote Link to comment Share on other sites More sharing options...
